1984 corvette hard starting and stalling after headers installed
Old Nov 3, 2016 | 10:32 AM
nelsonvazquez's Avatar
nelsonvazquez
Default 1984 corvette hard starting and stalling after headers installed
Hi All
decided to install a set of short headers on my 1984 corvette,after that took it to a garage to weld all mufflers,when pick it up at the garage start stalling and stumbling took it home and let it there until week end,change wires burned by headers,installing new oxygen sensor(broke it at garage)
set an elbow on the knock sensor (new) in the opposite side of block due to space,check everything and start but stalling and stumbling, Jump OBD but no codes at all,change ECM because I have another but still no codes neither lights on the center dash, disconnecting coolant sensor and work better, bought a new one crank it runs ok move it,wash it and later did not work still stalling and stumbling, disconnect EGR close opens on TBI and EGR valve nothing still the same.
stalling,stumbling and smoking a lot
any ideas?
Old Nov 4, 2016 | 02:41 PM
mikem350's Avatar
mikem350
Start with basics and check all the plug wires, CHECK FIRING ORDER, they may have mixed em up.
Plugged cat converter?
Old Nov 5, 2016 | 10:02 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Originally Posted by nelsonvazquez
Hi All
any ideas?
First things first... Do you have an 84 GM Service Manual? If not, you need to get one. If you want, PM me and I'll hook you up.
There could be a lot of different things causing your issue.
Old Nov 6, 2016 | 12:40 PM
nelsonvazquez
Checked several times
cat converter is connected to the main system but the connection in the side that goes to the manifold is close due to the installation of the headers.
Old Nov 6, 2016 | 12:41 PM
nelsonvazquez
yes I have one
Old Nov 13, 2016 | 04:04 PM
nelsonvazquez
Default Success
I may found the problem,when disconnect EGR valve and close outlets on TBI and valve did not disconnect the sensor and apparently keep connecting and troubling the electronics,after several tfy outs it is running ok, will need to keep checking for any code or ECM situation.
Thanks all for your support will let you know any news
To 1984 corvette hard starting and stalling after headers installed
