Smoke Plumes
Nov 6, 2016 | 08:43 PM
Smoke Plumes: Now with Video!
After my optispark adventures I thought I could at least drive the car. No such luck.
Once it gets hot I get smoke plumes pouring from the left side of the engine. It's oil hitting something hot, I assume the header?
I thought it was the dreaded manifold leak but I can't see any oil dripping from the back of the manifold.
Where else is it likely to leak, and a lot?
Thanks!
95 with 130k miles
Nov 7, 2016 | 10:53 PM
Is the oil sender on that side?
Nov 8, 2016 | 08:34 PM
Yes it is.Check valve covers for leaks,sender is below exhaust manifold but could leak onto pipe or cat.
Nov 9, 2016 | 03:36 AM
Valve cover gaskets were recently replaced but I will recheck.
I need to check the sender. Is it a common failure point?
Nov 19, 2016 | 10:31 AM
Amazing what you can see with a $15 camera.
