high cold idle
Nov 7, 2016 | 06:33 PM
2nd Gear
high cold idle
Hey Guys,
I need help, I have a 1984 Corvette that cold idles at 2300rpm for about 4 minutes and then backs down to around 700rpm at idle in park. The car will run correctly the remainder of the day, however after the engine gets cold we have the high rpm again.
I have changed both idle air control valves and that did not help.
Anyone have any suggestions?
Thanks,
larry9j
Nov 7, 2016 | 07:43 PM
Welcome to the forum.
For more exposure and responses, post this question in the C4 Performance / Tech area.
Nov 7, 2016 | 07:55 PM
Quote:
Originally Posted by
rkj427
https://www.corvetteforum.com/forums...erformance-48/
Nov 7, 2016 | 10:15 PM
Nov 8, 2016 | 08:07 AM
Welcome and good luck with your eighty four!
Nov 8, 2016 | 08:12 PM
2017 C6 of Year Finalist
Nov 10, 2016 | 01:10 AM
Moved to the C4 Tech area.
Nov 10, 2016 | 07:33 AM
I'd update the coolant temp sensor & plug in to the newer style. Check for vacuum leaks.
