cold start injector
Old Nov 7, 2016 | 10:16 PM
gman35's Avatar
gman35
Default cold start injector
Does anyone know if you can eliminate the cold start injector on a 1987 C4 L98 intake, so a later model accel TPI manifold can be used?? thanks, gary
Old Nov 7, 2016 | 10:27 PM
Dt86's Avatar
Dt86
I did on my 86 when I put a hi flow intake on. I just cut, crimped and tack welded the fuel line where it comes out of the fuel rail.
Old Nov 7, 2016 | 11:00 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
my understanding is that yes you can remove it from the thne and block it off.
not sure about a later year L98 intake on the 87.
Old Nov 7, 2016 | 11:12 PM
John A. Marker's Avatar
John A. Marker
Yes, you can eliminate it. You can purchase a plug to plug off the fuel rail. It will take a few more cranks to start the car, unless you change the programing to add a little more fuel at startup. If you change the program, you will not notice that it is gone and startup will be like normal.
To cold start injector
