Targa top issue **SERIOUS ISSUE**
Old Nov 8, 2016 | 12:34 AM
The Thomas J's Avatar
The Thomas J
Default Targa top issue **SERIOUS ISSUE**
I get one issue resolved and another pops up. While I was on the highway the other day doing about 75mph I hearair rushing into the interior. I look up and I see a gap in the Targa top. I pulled over and attempted to tighten it and it was tight as in not loose at all. I continue driving and it happens again. Upon further inspection,I realize that the glass is becoming separated from the frame. This is the first time I have ever experienced something like this in 28 years of driving.
Has anyone else experienced anything like this before? Is it a common issue? Is it fixable? Should I get some silicone and attempt a repair or look for a new top?
How my Vette makes me feel.
Old Nov 8, 2016 | 01:02 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Unfortunately, loose tops aren't that uncommon for our C4's. Don't ignore the problem! The FRC (Flying Roof Club) already has too many members! Here's a link to my repair procedure, which is holding up just fine, after about 8 years!
https://www.corvetteforum.com/forums...ir-advice.html
Good Luck!
Old Nov 8, 2016 | 04:15 PM
whalepirot's Avatar
whalepirot
Mild mannered reporter for the Daily Planet, until he enters his virtual phone booth!
Old Nov 8, 2016 | 05:21 PM
Christi@n's Avatar
Christi@n
Good Luck!
Amazing
Old Nov 8, 2016 | 05:23 PM
Christi@n's Avatar
Christi@n
You said glass is separated...
Windshield did you mean? Or t-top "glass"
Old Nov 10, 2016 | 06:34 PM
cuengineer's Avatar
cuengineer
When you say the fiberglass top is separating from the frame, are you referring to the frame as the part that bolts on to the brackets? The reason I am asking is that the think metal strip that is on the front and side edges of my fiberglass top keeps coming loose. So far, I have used a rubber mallet to put it back in place so I wondered if this might be leading to the problem that you are having. Been trying to figure out a more permanent solution but not sure what kind of adhesive or other idea might work?
To Targa top issue **SERIOUS ISSUE**
