What shocks to get???
I put a set of the Koni "Yellow Singles" on my 93 Ruby 40th ZO7 back in the 90s and I still love them.
If you're a serious autocrosser and want the best for competition, I would go with the Penskes Triple Adjustable with external reservoirs or the JRIs and have them designed and valved by Mike Maier, Inc. Race with them or race and get beat by them. I am using the Penskes Triples on my 89 Z51 that is no longer a Z51.
I have the FX3, had them rebuilt years ago to the Moracca valving. I felt like the original Performance setting was stiff, but not too stiff on smooth roads. With Moracca the Tour is like the stock Perf. setting, the others are too stiff for the street IMO.
Here is some info on FX3, Bilstein, and the Moracca valving. http://zr1.net/forum/archive/index.php/t-19314.html
At some point will switch to another, probably not use the FX3 system.
Not sure what I will go with, that is why a chart would be good to compare, especially between mfr's. The Bilteins Sport are stiffer than the HD's, the Konis Yellows are stiffer than Reds, but how do they compare to Bilsteins, can the Yellows be softer than REd in softest setting, can they be stiffer the the B. Sports? Are the Reds softer than the B. HD's? Reds VS KYB? etc.
