What shocks to get???
Old Nov 8, 2016 | 09:13 PM
NVNO1's Avatar
NVNO1
Default What shocks to get???
So my 94 vert is on its original shocks. It only has 4k original miles on it. My last 94 I had which was years ago, floated down the road like a luxury car. Kind of like a cadi. This one feels the same. What are the best shocks to put on the car to make it feel better, not so floaty. I'm looking for faster/better compression/rebound. If there are shocks I can get to make it feel closer to how my C5 Z06 feels I'd be happy. Suggestions?
Old Nov 8, 2016 | 09:49 PM
aklim's Avatar
aklim
If they are not FX3 it should be cheaper to get Bilsteins and if you don't like it, have them revalve it to your liking. It is really hard to compare worn out shocks with new ones though.
Old Nov 9, 2016 | 08:31 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
If you go ahead and buy Bilsteins, choose were you buy them based on price and also warranty service. If a Bilstein goes bad, they have to be returned to the place of purchase (there are exceptions, you need to look on the Bilstein website).
Bilstein's are warranted for life to the original purchaser and they do owner their warranty. The ones on my truck were replaced for me. (This is only for non-oem shocks, Bilstein doesn't warranty factory supplied shocks).
http://www.bilsteinus.com/products/s...vice/warranty/
I purchased my set for the Corvette from Summit Auto Racing. The ones on my truck were purchased through Autozone. You do have to keep proof-of-purchase. Summit and Autozone both maintain electronic records.
Summit will also price match and ships for free on orders over $99.00
Old Nov 10, 2016 | 09:45 AM
MatthewMiller's Avatar
MatthewMiller
Another interesting option is the "handling quality" shocks from Ridetech. They are around $700-750 for a set of four, and are monotube designs with adjustable rebound based on Fox internals. That seems like a hell of a good value, and you can adjust them however you want. I know they can be custom valved, too, but I think for your application you'd be in good shape with the off-the-shelf valving.
Old Nov 10, 2016 | 03:02 PM
Mike 92LX's Avatar
Mike 92LX
Koni or Bilsteins on a base car
Old Nov 10, 2016 | 03:41 PM
aklim's Avatar
aklim
IF I didn't have FX3 I would have tried it
Old Nov 10, 2016 | 06:21 PM
ddahlgren's Avatar
ddahlgren
I must have been under a rock too long after looking at the prices for C4 shocks and wow is the only word that comes to mind.
Old Nov 11, 2016 | 05:23 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I am not sure if they have AC Delco shocks for your year but if they do they are more affordable than say bilsteins.
Old Nov 11, 2016 | 08:11 PM
aklim's Avatar
aklim
Yes they cost less up front but if you have them on your car and buy it new, the warranty is manufacturer warranty. NOT lifetime replacement. Less money up front but more in the back end.
Old Nov 11, 2016 | 08:19 PM
MatthewMiller
The original poster wanted shocks with higher damping rates for a more controlled and responsive handling setup, though. I doubt that AC Delcos or other OE-equivalent dampers will do that for him.
Old Nov 12, 2016 | 03:31 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Performance vs price. Or QA1's
Old Nov 15, 2016 | 12:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
KYB makes a well priced super durable shock youll never have to replace one. They do stiffen the ride up. Not a "smart shock" like the Koni Bilstein etc but if you dont have a stiff spring the may work out for you been using them since the 80s on every car Ive had. Only one kinda regretted was the 89 it was already stiff, on a rough road wow thought the car was coming apart. Anything else been real happy
Rebuilding Bilsteins not worth it imo btdt. Worked fine but cost too much by the time all was said and done no lifetime warranty
Old Nov 15, 2016 | 02:20 PM
desertmike1's Avatar
desertmike1
My Shocks where worn out as well, causing a Baby Buggy "Wondering" ride.. KY"s and all is good!
Old Nov 15, 2016 | 08:23 PM
A Peter C4's Avatar
A Peter C4
Tonico shocks are lifetime warranty,has anyone had experience with these?
Old Nov 15, 2016 | 08:25 PM
aklim's Avatar
aklim
On another car, yes. Fairly decent
Old Nov 16, 2016 | 08:15 AM
FWC's Avatar
FWC
St. Jude Donor '13, '15-'16,'18 thru '25
When I replaced the shocks on my 96 base coupe I went with the Z51 option from Bilstein, seems to have eliminated the float and softer ride built into newer models. I say this haven driven a number of later C4s to compare to mine.
Old Nov 16, 2016 | 11:54 AM
aklim's Avatar
aklim
I just talked to Bilstein. If you rebuild the OEM shock, it is a 90 day warranty. On my aftermarket Bilstein shocks, it is lifetime. HOWEVER, if you revalve, it is considered a custom shock so the lifetime warranty is voided.
To What shocks to get???
Old Nov 16, 2016 | 12:02 PM
ddahlgren's Avatar
ddahlgren
Will Bilstein offer advice shock dyno test results so someone else can? Sometimes paying a shock guy with known corner weights and wheel rates shock dyno data along with expectations will save a ton in experiments. Sure going to spend a hundred or so for a short amount of time but compared to the cost of picking the wrong ones cheap.
Old Nov 16, 2016 | 04:31 PM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Went with KYB and am satisfied...
Old Nov 17, 2016 | 07:20 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
