Dara logging and tuning
an ostrich 2 which is awesome. My BLM's were in the 150s, a new
friend I met from thirdgen.org suggested before I go in depth with
changes in the tune, to try changing size of injector size in the tune,
I changed it from 22.3 to 19 and BLM's are near perfect now at
128 to 130, car runs very well, I have some knock counts at 2800 rpm
to look into, question is should i leave this way or get into the maps
instead of leaving injector size changed,
also was suggested to go to a heated o2 sensor which i will do, and a
wide band o2 also.
chris
wide band o2 also.
chris
By increasing the PW, more fuel is delivered which brings down the lean condition (from the 150's). As a result, less "trim" is needed to correct normal running conditions.
Brian is also saying you may not be as rich in open loop operation such as start-up and WOT operation -- where fueling is calculated based on static parameters. And, if they aren't "correct", you may not get the results/performance desired.
Fueling tables aren't that complicated. IIRC, target BLM is 128. If you see 150, Divide 150/128 = 1.17 Multiple that times the MAF table entry that corresponds to the MAF grams where 150 BLM is observed. In general, fueling should be smooth/linear from cell-to-cell -- which should also help build a new, closer table.
150 represents fuel being 17% low/lean. Notice the OP lowered the injector size by 17% in an attempt to accomplish the same thing.
on the motor, that being the lean condition I'm sure, I'm getting ready
to do a cam which I'm sure will open up a new can of worms, as to part 2 of my question do you think the 3 wire 02 is necessary? I think it certainly will be when I do full length headers. If anyone is interested I will tell you that the miniram with no other mods at all made a huge huge difference in performance especially above 4000rpm
it pulls very hard to 6000 and more, cant wait to do cam and full length headers
wide band o2 also.
chris
ADX file you use? windata seems to monitor so much more than tunerpro for me, so ive been using windata to datalog and tunerpro to edit and upload to the ostrich
thanks
