gm code reader
Old Sep 17, 2002 | 07:34 PM
mjfox's Avatar
mjfox
Default gm code reader
has anyone used the gm code reader does it cover the sensors ,abs,asr
and anythingelse
thanks mj fox
Old Sep 17, 2002 | 07:54 PM
don hall's Avatar
don hall
Default Re: gm code reader (mjfox)
What model code reader are you using?
Old Sep 17, 2002 | 08:02 PM
vader86's Avatar
vader86
I wouldnt spend the money on it. There are other ways to pull codes, but i'm not sure of the LT1.
Yes it would cover all trouble codes, which includes all sensors.
Old Sep 17, 2002 | 09:27 PM
mjfox's Avatar
mjfox
Default Re: gm code reader (Oldman)
it is the one that cost $30canadian
Old Sep 17, 2002 | 11:05 PM
don hall's Avatar
don hall
On page 4-25 in the MIDAMERICA DESIGNS catalog, there are two options:
1. Grounding plugs for: EMC, CCM, ABS/ASR, FX3, low tire pressure. --$40 American
2. ALDL tool (same category of codes) ---$80 American
Both items were designed by Gordon Killebrew. The ALDL will display history codes, and erase codes without disconnecting the battery. The grounding plugs will not erase codes. (Or you can use a paper clip as a grounding device.)
I would recommend the ALDL tool, just for the convenience provided. It's your budget.
To gm code reader
