Please Help Marker Light Problem
I checked the connections and sockets still no good. When the engine is on both drivers front Marker lights remain on???
So my problem has changed from front Passenger side Markers being off (which I learned is as it should be) to Both Drivers side front Marker lights being on when they are not supposed to be.
All other lights work fine including the front Markers when the light switch is engaged. Signals and Hazard lights work fine.
This is very confusing, although I don't have to worry about possible tickets.
Barrier
Barrier
http://www.webelectricproducts.com/products.htm
In the "left margin" is a link to "on line instructions" - see if maybe you can make sense of the wiring presented for the C4 from the C4 link in the "on line instructions". Look also at the "VERY GENERIC" instructions for the kit also. It's maybe a very early install that was attempted before the install was verified and documented by a very talented C4 owner.
The link won't stick so just sort through the "left column/margin" links on the web page.
Thanks again for all your help and the others who have posted.
To continue...
Barrier
That module was wired in, one wire was loose. I didn't bother to reconnect I just removed the whole thing and tested the Markers etc.
I have photos of what it looked like in and out.
Now to reconnect cut wires solder and tape it all back.
Thank You, Thank You!
Barrier
Barrier
