engine stills runs rich
Old Nov 25, 2016 | 07:42 PM
dbergair's Avatar
dbergair
Default engine stills runs rich
Hello all. Me again. My 85 corvette still runs too rich. Way too rich. Like you cant drive it rich. I have replaced the MAFS,CTS,O2 sensor, fuel pump. I have tested the fuel injectors and inspected the fuel pressure regulator. I get 40 psi with engine running and with ignition switch on. I bought a new ECM and prom card. It wont run with calpak removed which leads me to believe the car is in limp home mode. I repaired numerous problems in the ecm harness and the TPS seems to check ok. I think this car has more electrical problems but hope that someone has maybe seen this before. Any help is greatly appreciated. Thanks
Old Nov 25, 2016 | 07:47 PM
ex-x-fire's Avatar
ex-x-fire
I'd do a resistance check between the cts plug in & the ecm connector. Check the ecm grounds too. You might have to hook up a scanner to it.
Old Nov 28, 2016 | 01:30 PM
aklim's Avatar
aklim
Why did you replace all that? Was there some diagnosis done? It won't run without the EPROM because all the calibration information is there. As to the fuel pressure, I suspect it is well but what is it when you turn on? Does it spike up and hold? At what pressure? What is the WOT value? Who gave you the EPROM chip? What spec was it set to? How did you test the fuel injectors? Did they tell you what the flow rate was so we can see if it is right for the car?
Old Nov 28, 2016 | 07:06 PM
tuneportbeast's Avatar
tuneportbeast
I would suggest checking grounds. The one on the thermostat housing in particular. My 85 did the same thing and I found that the metal o-ring ground that the thermostat housing bolt goes through was broken and was barely making contact which explained why after it was warmed up on certain days it would stop running rich like a snap of the finger and ran perfect. Just my 2 cents.
Old Nov 28, 2016 | 07:10 PM
antfarmer2's Avatar
antfarmer2
Water temp sensor and cold start injector if it has one.
Old Nov 28, 2016 | 08:24 PM
pcolt94's Avatar
pcolt94
You need to get a professional scanner or a Tech1 (or 2) that can read OBD1 and look at all the inputs that the ECM is seeing and what the fuel trim is. Checking for open/closed loop, temp input, TPS and MAP are some of the basic things you need to know to see what's happening.
If you can't do this, get somebody smart that knows what they are looking at. Or you will be messing around for the next year.
Old Nov 28, 2016 | 11:53 PM
aklim's Avatar
aklim
I don't think it has a MAP, does it? Shouldn't it be a MAF?
Another possibility is the injectors are not spraying like they should and the only way to know that is with a bench test. Still, probably Multecs so might as well toss them and get rebuilds from FIC.
Old Nov 29, 2016 | 12:41 AM
dbergair's Avatar
dbergair
Default rich fuel mixture.
The MAF sensor was bad. Someone had tried to solder the wire loop inside it. I did some troubleshooting. The O2 and CTS were cheap so I replaced them. I was told the ECM and prom card were not the right ones. I bought the ECM from cardone P/N 77-6870 and the prom card from hypertech P/N 155371
The fuel pressure seems stable at about 40 psi. I will get the WOT number tomorrow. I assume that is the pressure? The fuel injectors were tested on a test bench and looked to have a good pattern. The injectors have a part #0-280 150 223 5-235 041 448 086 . Dont know the flow rate. My understanding was that the car would run on the cal-pak if something was wrong with the ECM or prom card. Thanks for the help. I appreciate it.
Old Nov 29, 2016 | 01:05 AM
aklim's Avatar
aklim
Soon as the wire is broke, it is junk so good call on that one.
Fair enough.
Cardone ECM probably is ok. The Hyperjunk part leads to THIS. That means you have a EPROM that isn't stock. Not sure what the settings are. I never trusted that sort of "off the shelf" stuff. People have torn the program apart and said all it does is turn on the fans earlier. At best no gain, at worst it introduces a variable. You might be better off getting a NOS unit on ebay or something.
If you turn the key on, it pressurizes and without engine vacuum it assumes WOT. So it should be about 43psi give or take a couple. If it holds AND you have the stock system for a while, it is good. If not, well, you need to go looking for issues in the fuel system. It might take a while like overnight and next morning it is anywhere from 0-20 for example. Again, good. OTOH, in 5 minutes if it is at 20 psi, you have issues.
Might I ask who tested them? IF it is FIC or RC Engineering or some other reputable company, they have charts to confirm what I am about to say. Look HERE.
Old Nov 29, 2016 | 01:06 AM
aklim's Avatar
aklim
Question. Have you been able to scan it and see what the O2 says for reading when it is running badly?
Old Nov 29, 2016 | 09:05 AM
aklim's Avatar
aklim
http://www.ebay.com/itm/NOS-1985-COR...1WEt~J&vxp=mtr
Is this the right one for you?
Old Nov 29, 2016 | 09:50 AM
pcolt94's Avatar
pcolt94
I was just throwing out some starting suggestions.
I believe you are getting MAF (mass air flow) confused with speed density sensors. The MAP (manifold absolute pressure) measures pressure in manifold which bolts on top of the manifold.
If for some reason the 85 does not use a MAP, then its just my lack of specific knowledge of the 85.
Old Nov 29, 2016 | 09:53 AM
aklim's Avatar
aklim
I'm not sure myself. I thought 85 didn't have a MAP and was MAF but I don't know for sure. I know that my 91 has a MAP and no MAF. Just asking
Old Nov 29, 2016 | 03:06 PM
xrav22's Avatar
xrav22
1985 is maf, I would agree with post above to check the things that control fuel ratio.
The water temp sensors on the front of the engine.
Also all connectors need cleaning I've noticed on mine.
Old Nov 29, 2016 | 04:59 PM
aklim's Avatar
aklim
I'm a little nervous about the connections. Sometimes the connection part gets brittle so be careful and use a bit of dielectric grease
Old Nov 29, 2016 | 10:24 PM
pcolt94's Avatar
pcolt94
With some of the info I have and taking a closer look it seems the 85 does not have a MAP sensor but it does use a MAF sensor. One less item to check.
Old Nov 30, 2016 | 03:09 PM
dbergair's Avatar
dbergair
Default 85 fuel issue
Fair enough.
This is great info. I will research the injectors and check to see how long the system will hold pressure. OTOH? Thanks for the info
To engine stills runs rich
Old Nov 30, 2016 | 03:11 PM
aklim's Avatar
aklim
On The Other Hand
Old Dec 11, 2016 | 12:07 AM
dbergair's Avatar
dbergair
Default still runs rich
On The Other Hand
Hello all. My fuel injectors are bosch 280-150-223 that flow 21.35 lb/hr. at 36 psi. It definitely wont hold 40 psi overnight. I will time it tomorrow. Where does the vacuum hose to the FPR come from? The car came with an ecm from a 91 cadillac and the prom was from a 85 firebird HLM designation. The car wont run on the ECM i bought at all. Any help is greatly appreciated. Also I am considering a carb if i cant get it to run right. Thoughts?
Old Dec 11, 2016 | 12:37 AM
aklim's Avatar
aklim
Talk to Jon and see if he knows what the right injectors for you are. I'll bet he does. Overnight, it might drop to say 20 but it should hold 30 for at least a half hour, IIRC from when I had that setup.
You might check on some programming boards if the 91 Caddy has the right ECM. Not sure what the 85 F-body eprom does.
I don't know if you want to do that. Without the ECM, you might have to wire gauges. For a pure race car, no problem. How did you come on that ECM and EPROM combo? Did someone who checked calibration tell you that? According to Tunerpro site, you should be using ECM part number: 1227165 and your broadcast code should be, according to ChevyThunder: HLP
