85 ECM and Compression Ratios
After consulting with my C4 brethren on crate engines, I'm fairly certain I'm going to go with an ATK short block and add my 91 118 heads and intake to that. I also plan on using a cam close to the stock specs.
Using that block and my heads, doing a quick calculation on Summit's site, the compression comes out to be roughly 10.41 :1 using a head gasket of .041 compressed thickness. Is that ratio too much for the 85's ECM to handle or should I get a thicker head gasket?
Bore: 4.040 in
Stroke: 3.48 in
Cylinder Head Volume: 58 cc
Effective Dome Volume: +6.9
Compressed Gasket Thickness: .041
Number of Cylinders: 8
Compression Ratio: 10.41 : 1
Bore: 4.040 in
Stroke: 3.48 in
Bore: 4.040 in
Stroke: 3.48 in
Bore: 4.040 in
Stroke: 3.48 in
It should be cam selection is a factor. Actual compression will be lower because unless you have "forced induction" cylinder will not have 100% filling. 75-80% I would expect. A fast acting cam can promote cylinder filling. Cams with a lot overlap can reduce filling.
