Sensor ID'ing
Old Dec 14, 2016 | 04:26 PM
Adam2980's Avatar
Adam2980
Default Sensor ID'ing
I am trying to identify the sensors that are on my 84 C4 with the stock 350.
Passenger side head: one wire that connector plugs into
Driver side head: One wire with a spade terminal
Intake Manifold by thermostat housing: two wire
Engine block by starter: one wire that plugs in
Engine block by oil filter: one wire with spade terminal
If anyone can help id these that would be great. Thanks
Adam
Old Dec 14, 2016 | 06:05 PM
WVZR-1's Avatar
WVZR-1
RH cyl head - fan switch
LH cyl head - coolant temp gauge
2-wire intake - CTS for ECM
RH block - knock
LH block @ oil filter - oil temp
Old Dec 14, 2016 | 08:35 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Plus . . . sensor at left side base of distributor is oil pressure.
Old Dec 14, 2016 | 09:06 PM
rorrapalooza's Avatar
rorrapalooza
Can anyone comment on which of these need to be changed regularly? I know the coolant temp sensor in the front of the intake can be a cause of poor idle.
To Sensor ID'ing
