Aftermarket coils/ignition for LT4
Sam
[Modified by LT4Sam, 12:21 PM 9/26/2002]
Don't flame me on this, but unless you need boost retard on an engine boosted by nitrous or a supercharger, you are wasting your money on any add on ignition box to your '96. Further, my experience says all you will get from an add on ignition box, MSD, Jacobs, whatever, is a shorter optispark life and less reliability.
My '95 runs a stock opti and an MSD low impedence coil, it never made more power with an add on box - but those ignition boxes sure left me stranded a couple of times. If you bother to really check out your ignition, you will also find that any of the multi-strike ignitions do odd things with the optispark - like multi striking on only 7 out of 8 cylinders.
Thomas
Your stock system will deliver the necessary 30,000 volts or so to the plug. You have a very good stock timing/spark system, assuming you keep it out of the car wash.
Before you spend money, ask for dyno results on a system close to your application. Then decide.
dlmeyers 90 coupe zf6 3 speed shocks
Second, the multiple sparks from an MSD gives better throttle response, and absolutely lowers emissions. I know this for a fact, because I've done an emissions test here in Houston with, and without, the MSD box functioning. Back to back tests on the same day, and the test without the MSD produced higher HC's and NOx readings.
I will agree with you on the reduced life of the distributor cap. It will eat up the terminals quicker. For me, it's not that big a deal considering the peace of mind I have with the good rev limiter.
I'm not looking at it to increase horsepower. I'm looking at it to maintain horsepower. Dual Rev Limiters, Nitrous Timing Retard, Easy Tach Output, etc.
I'll agree that it causes more wear on all parts of the system, but I can replace an opti in 2 hours and I can replace plugs / wires in 30 minutes. I'll take the added routine maintanence for the extra benefits you get. I too don't like the stock rev limiter, the MSD is such a better system.
The only thing I wouldn't consider in an aftermarket system is something like just and MSD 6A. It doesn't have any special features at all other than the improved spark power which as you said the stock system should be plenty.
IMHO, for $300 you should get an improvement in performance, not a less reliable car with higher cost repairs.
Eric
As far as poor mechanical design ("wires looped all over the place"), how about just doing a clean install? It's not necessary to loop wires all over the place. My MSD, and all the wires, are completely hidden from view.
I never said the PCM uses the factory tach to limit revs. If you read it again, I'm referring to the driver's ability to gauge when to shift. An inaccurate tach can cause you to overrev the engine, at which point a good rev limiter comes in handy. Hey, it's personal choice. To me, $180 is cheap insurance when I'm at the drag strip. It sounds like you've never run your car at the track, so I can understand you not wanting to spend money for an unnecessary item.
IMHO, unless you're running N2O/turbo/supercharger, on an LT1/4 all the aftermarket ignition boxes are a waste of money.
Eric
It is however a fact that the aftermarket electronic add on ignition boxes use lower grade electronic componentry than the factory, ask anyone inside the industry and they will tell you the actual defective return ratio is astoundingly high - no quality circles here! However, a lot of the $$$$ race equipment is quite good - but that's not what were talking about here.
They do however have their place, I absolutely agree that an ignition based rev-limiter is superior to a fuel based rev-limiter. I just wish they were made to a higher standard, and the opti does get punished by the multi strike boxes.
What I can say is that I have seen more than a few add on ignition boxes where there were no indications that anything was wrong, but that was only because the owner never scoped his ignition. Opti's and multi-strike do not go together - I challenge all who have one to scope their ignition, I'm positive that a huge percentage will report back that not all cylinders get the multi-strike.
One of my favorite local dyno facilities has a regular practice of doing one of a customer's dyno pulls WITHOUT the multi-strike box hooked up. Take a guess how often they tell people to run their car without the multi-strike!
I am sure that there are people with positive experiences with the add on ignition boxes on optispark engines - but with absolutely everyone I know they have mostly killed their opti's much earlier than need be.
Do what you must with a heavily modded engine, sometimes a sacrifice in the reliability of one component can have good trade off benefits.
If you have a stocker, near stocker, mild performance LT1/4 engine, then in my opinion it is a waste of money with no clear benefit.
Thomas
