1992 Corvette loses fuel pressure
Old Dec 22, 2016 | 05:42 PM
aklim's Avatar
aklim
Originally Posted by bjankuski
I doubt this is a fuel pressure problem, more then likely you have a modified engine and you need a tune that will add more cranking fuel, and open loop fuel. If the pressure hits 40 with the key on and then slowly drops it will be fine when you are cranking because the fuel pump is on when you are cranking.
FYI, the fuel pressure drop get blamed for all kinds of issues when it is usually not the main starting or running problem. If the fuel pressure rail pressure stays in the 30's and 40's when the car is running the problem is located somewhere else.
My car does not have a starting problem and my fuel pressure will drop to zero in 10 seconds. There is no starting problem because as soon as I hit the key and start cranking the pressure jumps up to 40 PSI and the car immediately starts. Fuel is non compressable and even a very slow leak back to the tank will cause the fuel pressure to drop to zero very quickly.
Originally Posted by Eddie4694229
If the vehicle sits for say 12 hrs or so it takes a good 5 min or so to pump the fuel back up to the injectors.
All you say is true but the part that he says that it takes 5 mins to pump fuel to the injectors makes me wonder. Soon as you hit the key to run, it pressurizes for a few seconds. Mine drops like you mentioned but it still hits 43 psi in an instant and NOT 5 mins.
Old Dec 22, 2016 | 05:44 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
yes, something is going on with taking five minutes to re-pressurize.
if the filter or the sock was plugged, it would take just as long to pressurize the initial key on. This one is a real mystery
Old Dec 22, 2016 | 05:47 PM
aklim's Avatar
aklim
That was my confusion too. That it takes a while to DE-pressurize makes me think it is a pump issue. Either current or the pump itself. We might know more if he comes back with a test result.
Old Dec 22, 2016 | 05:57 PM
Eddie4694229's Avatar
Eddie4694229
I had a chip burned after the motor was built with all the updated specs. Any suggestions on how I can determine if this is a fuel pressure issue or an issue with the chip?
Old Dec 22, 2016 | 07:14 PM
bjankuski's Avatar
bjankuski
Put a fuel pressure gauge on the rail and crank the car, does the fuel pressure rise up to around 40 PSI quickly and stay there as long as you are cranking the car? If it does it maybe a chip issue, if the pressure stays low until the car finally starts the issue will be fuel pressure related.
How did you obtain the reading you listed for fuel pressure if you are buying a gauge tomorrow?
Old Dec 22, 2016 | 07:31 PM
lt4obsesses's Avatar
lt4obsesses
The psi comes up to appx 40 psi, and it appears it is a "slow leak" the longer it sits the more it leaks down. If the vehicle sits for say 12 hrs or so it takes a good 5 min or so to pump the fuel back up to the injectors. The motor is still an lt1, to compound the issue once it does finally start the motors revs between 1-2 thousand rpm's. It takes about 20-25 minutes before the motor starts running properly (even after warming up for about 10 min prior to driving). Is there any chance the initial rough idling is related to the leak down issue? Thanks for all your help, I have been restoring this car for about 2 years now, its been to multiple shops and to this point no luck in figuring out the leakdown problem.
What happens to fuel pressure when you rev it?
Pressurization should be pretty much instant. When you turn the key to the "on" position, you should hear a buzzing noise from the back, that's your fuel pump. Pressure should be between 41 and 35 psi. When turned off, it should take about 30 min to fully depressurize.
I suspect one of two things, assuming of course that the regulator is good, and installation was correct. Either you don't have enough fuel pump for a 383, or the open loop tune is off. Or both.
Old Dec 22, 2016 | 07:34 PM
Eddie4694229
The mechanic that was working on it before tested the pressure, and that's what he came up with.
Old Dec 22, 2016 | 07:39 PM
Eddie4694229
. After the motor gets completely warmed up it revs fine however with that being said if I am running say 65 or 70 in 5th gear and I step on it, the motor stumbles. As long as the acceleration is slow and smooth at the top end it's fine but if you step on it hard it stumbles.
Old Dec 22, 2016 | 07:51 PM
lt4obsesses
5th gear is an overdrive gear, so stepping on it, while it shouldn't be a huge chore for the engine, isn't ideal. However, stumbling on acceleration is typically a fuel delivery issue. Kind of why I asked about the fuel pressure when revving. It may rev okay without a load on it, but the pressure gauge may show a larger than normal drop in pressure. Supply needs to match demand.
What size injectors are you running? From everything that I've heard and read, most people going 383 also upgrade the fuel pump as well.
Old Dec 22, 2016 | 08:07 PM
Eddie4694229
I'm running 30 lb injectors, it's a manual transmission, is there a fuel pump you suggest?
Old Dec 22, 2016 | 08:31 PM
lt4obsesses
https://walbrofuelpumps.com/vaf/prod...ar=8&engine=33
Old Dec 22, 2016 | 08:39 PM
Eddie4694229
Thanks for the advice I'm going to order that fuel pump. Do you think the 30 lb injectors are sufficient?
Old Dec 22, 2016 | 11:44 PM
  #33
lt4obsesses
Before spending money on the pump, I would confirm as best I could that it is indeed a fuel issue and not an ignition issue. Nothing worse than throwing parts at the wrong problem.
Old Dec 23, 2016 | 02:00 AM
  #34
aklim's Avatar
aklim
As the chip been programmed to take that new upgrade in mind?
Old Dec 23, 2016 | 02:04 AM
  #35
aklim's Avatar
aklim
http://www.racetronix.biz/customkiti...kc=FPA-010&eq=
Getting it from Walbro is $121 and it doesn't have the gasket or the bolts to replace the old ones. Why not get it all for $90
Old Dec 23, 2016 | 06:53 AM
  #36
Eddie4694229
The chip has been programmed for the upgrade.
Old Dec 23, 2016 | 06:57 AM
  #37
aklim's Avatar
aklim
Assuming you told the programmer about the mods and the larger injectors, I'd check the pump to regulator area
To 1992 Corvette loses fuel pressure
Old Dec 23, 2016 | 07:11 AM
  #38
Eddie4694229
Thank you for your help, I did give all the specs when the chip was ordered, I have had a ton of problems getting the motor to run consistently. The performance or lack thereof changes almost every time I drive the car. Its very frustrating.
Old Dec 23, 2016 | 07:19 AM
  #39
aklim's Avatar
aklim
Hate to say that but an off shelf or mail order tune has never left me satisfied. I usually get it done at the facility so they can fine tune it instead of guessing what you have and write the program conservatively. Also in introduces another variable.
That said, let's look at the fuel pressure to rule it out. Check compression just to make sure
Old Dec 23, 2016 | 07:32 AM
  #40
Eddie4694229
I had the motor built at a race shop in Lynchburg Va. (Kowalski Racing) they don't burn chips so I had to order out of Ohio. I haven't been able to locate anyone locally who can burn a chip and tune it. Compression tests have been conducted by prior mechanic and I was told the motor itself is very solid.
