Help !! Losing power when cornering
Old Dec 26, 2016 | 01:36 AM
kocoach's Avatar
kocoach
Default Help !! Losing power when cornering
I have a 1987 corvette and just installed a new motor in it, new factory fuel injectors, new fuel pump etc,etc. My problem is when cornerning, not in a racing venue just on the street I lose power like it's starving for fuel, I have to give it a lot of gas pedal then it picks up and starts to run ok until I have to make another turn either right or left it does it. On cold mornings it starts then dies a couple of times and sometimes it dies when warm at stops. Does anybody have any insight as to what could be causing this very troublesome condition? Any help would be greatly appreciated. Thank You and GOD Bless.
Old Dec 26, 2016 | 07:04 AM
antfarmer2's Avatar
antfarmer2
Did you replace the pulsater with the proper hose?
Old Dec 26, 2016 | 10:04 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
How full is the gas tank?
On stock C4's it is fairly common for fuel starvation during cornering if the tank is about 1/2 full or less. It does not have to be on a track. On one of my favorite on ramps it happened to me several times. I corner fairly hard on the street, but not at racing levels.
Old Dec 26, 2016 | 10:12 AM
c4cruiser's Avatar
c4cruiser
On my old '87, I would see some of the same symptoms when the tank was down to around a 1/4. But this was at autocross and track day events. Didn't really see a problem on the street.
Did you replace the fuel filter? Did you replace the "strainer" at the bottom of the pick-up? What is the fuel pressure? Hook up a gauge to the valve on the passenger side fuel rail and turn the ignition to ON but don't start the engine. You should see somewhere around 40-45 psi. If the gauge has a long hose, you can tape the gauge to the windshield so that you can see the gauge. Drive around and duplicate the problem. What is the fuel pressure when the stumble occurs?
You can "rent" a fuel pressure gauge at AutoZone (pay a deposit and when you return the gauge, you get your money back). The fuel filter can be a PITA to change but it's well worth doing. If your car also has a filter on the return line, change that one too.
Old Dec 26, 2016 | 01:44 PM
kocoach's Avatar
kocoach
Default Baffle in fuel tank?
[QUOTE=kocoach;1593736257]All of those things have been checked out, we believe it may be somewhere a broken baffle in the fuel tank that when cornering without the assist of a baffle the fuel is allowed to move away from the fuel pump when cornering. We are going to check all of the aforementioned much appreciated suggestions over again as we are only human and may have overlooked something. Thank you guys so much the forum is the best.
Old Dec 26, 2016 | 02:23 PM
c4cruiser's Avatar
c4cruiser
If you pull the fuel pump, you should see a sort of "box" at the bottom of the tank where the strainer would be located with the pump assembly installed. With the tank empty, you should be easily able to see it by looking straight down.
It's designed to retain some amount of gas to keep the pump providing gas into the line. Unless there is rust or corrosion inside the tank that could have broken down the box, it should be there and holding some gas.
Old Dec 26, 2016 | 02:52 PM
kocoach's Avatar
kocoach
The tank was cleaned prior to engine installation.
Old Dec 26, 2016 | 03:52 PM
aklim's Avatar
aklim
And the baffle?
https://www.corvetteforum.com/forums...e-problem.html
Old Dec 26, 2016 | 04:36 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
This is most likely a fuel pump problem.
The fuel pumps lose pressure over time and start to push less and less. If this is the original, Id think of swapping it for a new one.
Of course, filter, screens and such...
Old Dec 26, 2016 | 06:08 PM
ex-x-fire's Avatar
ex-x-fire
Get one of those holley fuel pump strainers. They call them hydramats.
https://www.holley.com/products/fuel_systems/hydramat/
Old Dec 26, 2016 | 09:40 PM
aklim's Avatar
aklim
Do you speak from personal experience? I would be HIGHLY interested although I don't seem to have too much issue with that, you never know and I would not be opposed to it if it isn't costing me an arm and a leg and my nuts to find out.
Old Dec 26, 2016 | 11:02 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Spark or fuel..
Consider the act of a turn, what moves inside the engine compartment? The steering shaft, suspension a-arms, some g-forces....
What can shutdown the engine? Pinched line that closes when turning. Or ignition source? Loose or pinched wires?
Maybe setup up a FP gauge to monitor pressure when driving..
Old Dec 27, 2016 | 07:03 AM
ex-x-fire's Avatar
ex-x-fire
Nope, never tried one. I never looked at the price of them, but I'd get one next time I have the pump out.
Old Dec 27, 2016 | 09:48 PM
l98tpi's Avatar
l98tpi
Max G’s
Something else to check is your connections from the fuel pump to the the junction on the underside of the sending unit. Just pull your complete sending unit out and look at all the wiring and connections. I have had so many issues with the fueling system in my 91. It was autoxed so it was always cornering hard and if there was a weak point it would show up. Most of the time it would be easy fixes but sometimes would take some time to find. And most of the issues would be the wiring from the pump running up to the junction. Good Luck.
Old Jan 1, 2017 | 09:31 PM
helphos's Avatar
helphos
Default Cornering and fuel starvation
I took the fuel pump out to see if the 'tray' had been knocked loose, since that was cited by others as a primary cause of starvation on cornering. The tray was right where it's supposed to be, and was not at all loose. If I'd thought about it, I think I would have replaced the fuel pump while everything was out, but I didnt. The starvation issue only occurred when I was lower than a half tank, so when I autocross, I fill it up before the event. Still, I'd like to solve the problem permanently.
Old Jan 2, 2017 | 12:05 AM
aklim's Avatar
aklim
Some have tried to build a better baffle around it
Old Jan 2, 2017 | 12:36 AM
Cliff Harris's Avatar
Cliff Harris
The symptoms described are usually caused by a leaky connection between the fuel pump and the supply line to the fuel rail. When the leaky spot gets exposed to air by moving fuel, the fuel sprays out instead of going up the pipe like it's supposed to do.
Common causes are a short fuel pump that doesn't allow the pulsator to make the connection to the supply line. Another thing that can cause this is non submersible fuel line replacing the pulsator. Your fuel line might look like this:
To Help !! Losing power when cornering
