87 Trouble Code 42 ECT
Old Sep 20, 2002 | 12:36 AM
John G 92's Avatar
John G 92
Default 87 Trouble Code 42 ECT
this code 42 came up on my 87 last Friday. I was wondering if anyone else had this code and what fixed it. Back some months ago my PCM went bad and I replaced it and the Chip with a Delco Reman Computer. Today I installed a new Module in the disturbuter and that didn't fix it. The car run and I still drive it sometimes the light won't come on mut 90% of the time it comes on. The distributer connector looked ok (white EST wire) and I checked it at the PCM that checked out ok. Any input would be helpful thanks everyone.
Old Sep 20, 2002 | 01:16 AM
vettl83's Avatar
vettl83
Default Re: 87 Trouble Code 42 ECT (John G 92)
Right off the shelf all it says to do is check wiring at ign. mod. r&r ign. mod. or possible ecm failure. Remans have been known to go south on short notice. Good luck 84 CF 91 ZR-1
Old Sep 20, 2002 | 02:17 AM
J Z06's Avatar
J Z06
If it's worth anything, mine had this today after checking the timing.
Old Sep 20, 2002 | 09:43 AM
vettmech's Avatar
vettmech
Default Re: (JD 90 383)
You will get that code after checking the timing if you check it properly because you have to unplug the "set timing connector"........ that sets a code that should be cleared but if you don't it will be ok and clear on it's own after 40 drive cycles :seeya
To 87 Trouble Code 42 ECT
