Have my cert, need a reputable source for r12
i want to recharge my 1993. Don't want to do a conversion, just feel like I need to top off my r12.
I need a reputable source and the hose/gauge to do the fill.
Many suggestions?
Many suggestions?
Find the leak first
Have you found and repaired the leak? If not you will be shortening the lifespan of your compressor by simply charging it up.
If the fittings are original, any standard 1/4" charging hose will fit. I think I might have a really old can of the stuff laying around somewhere.
Envirosafe sells what you need.
eschoendorff (01-03-2017)
Mexico.
If you don't "trust" the source of your R12, check it. You need to accurately know the temperature the can and its contents are at, the pressure in the can, and have an R12 temperature vs pressure chart. If there may be air in the can, vent the gas and recheck pressure: If the pressure dropped, there was air. When the pressure is stable after venting, look at the chart.
My experience has been that thieves were marketing R22 as R12 in the South Bay area of SoCal about 10 years ago. R22 is about 30lbs higher at room temperature. Was pretty easy to verify.
Someone here must must have dealt with this before and had a favorable transaction with a vendor or source. I'm not looking to hunt on eBay if someone here has a better source.
this is what I want to avoid. I just want a reputable source of actual R12 (not a substitute nor a conversion).
