87 Corvette ECM tuning
I have an 87 Ragtop which I did a 383 with a lot of work and had a custom chip burned by PCM of NC.
http://www.pcmofnc.com/
I did end up sending it back a couple of times to get everything the way I wanted it. But if you don't have the access to a local tuner they seemed to work for me.
But if that is absolutely not feasible, go with an experienced tuner for a mail order, like Ed Wright, and you will need to get some tuning software like DataMaster or something that will let you record engine data and send back to him to get it right.
Eons ago, Jim Formato was an option. IIRC, after his death, it became something Eileen and Jeremy ran. Jim would send me to a Accel EMIC facility that they worked with before to do the datalogging or lend me Diacom. In the old days, it was us sending him the chip or getting the center to burn it, etc. IMO, if you do it without data logging, you are guessing based on the customer's SOTP feeling which is highly dubious. As said before, I'd be leaving something on the table since I don't want to push the limits without having the car in front of me, so to speak.
But ultimately after the last iteration (total of 3) the car seemed to run pretty good, that was a couple years ago now.
I think the key for me though, I was very specific about everything I did to my car. From cam specs, to wheel size, to rear end gearing. I didn't leave anything out, I also stressed to them I had an extreme port on my TPI base and ASM runners with 58 MM TB.
Anyway I finally put my car in the shop for some head work and potentially a new ECU, so will get a professional tune now, will see how that goes.
But generally speaking the mail order tune was enough to get the car running, then a couple of mild updates seems to work for me.
Mail order tunes will usually be good enough to get things going. I, OTOH, tend to be more **** about getting it spot on and less tolerant of "per the SOTP dyno, it is ok" which is why I would never recommend mail order tunes unless they datalog and fine tune it. While it runs, my standard is that it is optimized. Kinda another reason why I will never have a carb when EFI is affordable. IMO, 3 choices exist. They either will strike gold and get it right the first time (highly improbable), push it hard enough that it creates an unnecessary risk at some points or more commonly, leave stuff on the table for safety sake.
