1995 performance chip or computer flash?
Old Dec 31, 2016 | 10:00 PM
z-corvette's Avatar
z-corvette
Default 1995 performance chip or computer flash?
I have a 95 lt1 and was looking into a possible increase in performance. Looks like this year has a obd2 plug but obd1 computer so does this mean it has the old school chip you need to replace or does it get a computer flash through the ALDL with a programmer? Thanks in advance
Old Dec 31, 2016 | 10:05 PM
WVZR-1's Avatar
WVZR-1
It's a PCM and requires programming
Old Dec 31, 2016 | 10:19 PM
John A. Marker's Avatar
John A. Marker
There is not a removable chip. The PCM must be "flashed" to be updated.
Old Jan 1, 2017 | 06:20 AM
z-corvette's Avatar
z-corvette
thanks for intel.
Old Jan 1, 2017 | 07:59 AM
Turbo Bob's Avatar
Turbo Bob
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Also have a '95 I purchased from the original owner. He replaced the Dana 36 rear with a Dana 44 with 3:54 gears, 1.6 roller rockers and had a tune done. But whoever did the tune never compensated for the gear change. I can't seem to locate any kind of hand held tuner that would do this. Any ideas or suggestions? Thanks.
Old Jan 1, 2017 | 08:29 AM
bjankuski's Avatar
bjankuski
Tunercat will allow you to make the changes with your laptop. You need the program, a definition file and a cable, total cost around 150 dollars.
Old Jan 2, 2017 | 09:00 AM
Turbo Bob's Avatar
Turbo Bob
Thanks for the info. Appreciate it.
Old Jan 2, 2017 | 11:53 AM
z-corvette's Avatar
z-corvette
I would like to flash the computer but I have no laptop. Is there a device where the mapping is included and all I have to do is plug it in and download it?
Old Jan 2, 2017 | 12:24 PM
MatthewMiller's Avatar
MatthewMiller
I'm not aware of one. I haven't looked for cables recently, but if all that is out there are serial port cables (the end that connects to your computer, as opposed to more modern USB cables), then you might consider looking at ebay and craigslist for an old laptop that actually has a serial port. This would save the hassle of using a serial-to-USB adapter, not all of which work well. You can probably get such a laptop for $100 or less. You can use Tunercat on Win7, but I'm not sure it works on Win10. If the old laptop you buy comes with XP, that's probably even better since you don't have to jack around with compatibility modes.
If you're thinking that 1999 called and it wants its technology back...you're right. OTOH, you might post where you're located and maybe someone can help you if all you need is to recalibrate your speedometer.
EDIT: Oops, got you confused with Turbo Bob. I'd say that if you want to work on performance tuning, you should really purchase the equipment noted above and dive in. You'll need to do significant learning, then logging, then tweaking the stock calibration, and finally logging some more to see how the changes affected the performance. Lather, rinse, repeat as needed. OTOH, http://www.lt1pcmtuning.com/tips/ has not only tons of useful guidance on doing your own tuning with the equipment we mentioned, but he may be able to create a tune for you and loan you the equipment to flash it and log the changes.
Old Jan 2, 2017 | 01:37 PM
bjankuski's Avatar
bjankuski
Fyi, tunercat does work with windows 10.
Old Jan 2, 2017 | 07:58 PM
z-corvette's Avatar
z-corvette
I checked that site and he lives in cinn oh, looks like he offers to tuneit himself locally.
Old Jan 2, 2017 | 08:00 PM
MatthewMiller
I checked that site and he lives in cinn oh, looks like he offers to tube it himself locally.
If you live around there, that's the easy-button solution.
Old Jan 2, 2017 | 10:56 PM
aklim's Avatar
aklim
I would imagine that if you absolutely needed to, you should learn how to tune. OTOH, if you are doing a "one off" thing, it might be better to let someone do it with a dyno. There is a learning curve which pays off later. That said, if you need to do it often, find a dyno facility and start learning. If you are constantly changing stuff for racing, spend the money getting dyno time and learning. I can't justify the time and money spent for a "one off" deal. I have mine set up and only had to retune for a better cold start that was irritating me. Even if you consider that, right there is 2 instances since 04.
Old Jan 3, 2017 | 01:10 PM
94VenomVette's Avatar
94VenomVette
make sure you get a datalogger for TunerCats so you can datalog and change parameters accordingly. IF you plan on doing it yourself
Old Oct 8, 2018 | 09:23 PM
dozerman1's Avatar
dozerman1
check with scotthansen.net he can help you.. P# is 775-530-5892.... he knows his sh.t
To 1995 performance chip or computer flash?
