TPS sensor problem
Old Sep 20, 2002 | 04:26 PM
hz900's Avatar
hz900
Default TPS sensor problem
Finally got my car to idle (see other posts if you like), but now it will idle but when I give it gas it dies. Checked the tps and it tested fine. Tested the sending wire and it is getting no signal from the computer. Tested the wire back to the firewall and it is good. My mechanic is going to test it to the computer this afternoon. If it tests good to there I am assuming it is the computer? Does this sound right to you guys? It was working fine before I started working on the intake. Any fuses or relays I could have blown? I am about to go insane with flustration :mad .
Old Sep 20, 2002 | 04:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: TPS sensor problem (hz900)
The ECM provides +5Vdc power and a ground connection and has one input from the TPS to monitor throttle position.
If the +5Vdc is absent you need to check for it at the ECM pin C13 (dk blu wire).
If you have the +5Vdc, as you advance the throttle, does the TPS voltage at the TPS connector increase?
Old Sep 20, 2002 | 04:50 PM
hz900's Avatar
hz900
Default Re: TPS sensor problem (65Z01)
I think he said he checked to see if it was getting power and it was, but there was no signal change in the input wire from idle to wide open throttle.
He is a competant mech and I'm sure he will figure it out, I'm just trying to save him some time which will also save me some money.
Old Sep 20, 2002 | 04:57 PM
65Z01's Avatar
65Z01
If there is no signal change in the input wire at the TPS I would first suspect the connector and secondly the TPS wiper.
With electrical equipment the first thing to check is the connectors, especially since you had this one opened up. A little TV tuner cleaner on the contacts may do the trick.
Since the ECM worked before the intake R&R and you didn't zap the ECM it should still be fine.
Old Sep 20, 2002 | 05:36 PM
hz900's Avatar
hz900
Maybe I misunderstood him but I think he said he unplugged the connector and tested the signal at the connector.
Old Sep 20, 2002 | 09:17 PM
dlmeyers's Avatar
dlmeyers
If he unplugged the connector, the only voltage he could get would be the 5 Volts from the ECU/PCU (likely the gray wire). If he backprobed the connectors while hooked up, he should get O volts (blk wire) and around .5 to .7 volts, depending on year, on the remaining wire. Then if he did a sweep check, he would backprobe the dark blue wire, advance the throttle, and look for a steady increase in voltage. Hooking up a scanner and going to the TPS readout should yield what the computer is actually seeing. This could be compared to what is showing up on the volt meter. The TPS is definitely suspect if you get an off idle problem. Darn cars.
dlmeyers 90 coupe zf6 3 speed shocks
To TPS sensor problem
