ac/heat vac line
Old Jan 8, 2017 | 06:48 PM
zapc's Avatar
zapc
Default ac/heat vac line
ok im aggravated, trying to clean up some loose wiring and dry rotted black looms for wiring and snapped off the brittle black plastic vac line that operated the ac/heating doors. seems like it disappears into the wiring harness behind motor, cant reach it if i wanted to, where does this come out of the firewall? or where does it connect to inside if i have to run a new line and new hole in firewall.
thanks, this is what i get for being ambitious in the garage with 8 inches of snow on ground. its an 89 with c68 i think, (digital conroller)
Old Jan 8, 2017 | 07:33 PM
WVZR-1's Avatar
WVZR-1
In all of that aggravation it seems maybe you've forgot what year your car is. along with the year you might mention if the car is manual AC (C60) or if the car is an auto AC (C68). I believe I can maybe guess but how about mentioning YEAR and C60 or C68
