oil filter housing
Old Jan 22, 2017 | 09:09 AM
preacher putz's Avatar
preacher putz
Default oil filter housing
HELP its stuck, 96 Lt1 oil filter adapter stuck, cant get it off.
have removed 2 bolts, have tried to remove by prying and buy putting
a filer on for a better grip. does anyone have any ideas
tks Pr. Putz
Old Jan 22, 2017 | 09:39 AM
STL94LT1's Avatar
STL94LT1
It's stuck by the paper gasket. Pry harder!
ghoastrider1's Avatar
ghoastrider1
I have never worked on an LT but does the adapter screw up in there?
Old Jan 22, 2017 | 09:43 AM
don hall's Avatar
don hall
Just a suggestion....no experience..... replace an old filter on the base,
and tap, wrench, anything to loosen the base without damaging the base.
The filter will absorb the punishment, not the base.
I'm aware of the space limitation in that area.
I'm not responsible any mishaps.
Old Jan 22, 2017 | 02:09 PM
preacher putz
Default oil filter adapter stuck
Put the filter on, took about 5 or 6 raps with a hammer and off she came. thanks for the info
Old Jan 22, 2017 | 02:18 PM
don hall's Avatar
don hall
Now, take your time replacing base so there are no leaks.
To oil filter housing
