A/C Fuse Keeps Going Out
Old Sep 21, 2002 | 11:41 PM
Ricks1989Roadster's Avatar
Ricks1989Roadster
Default A/C Fuse Keeps Going Out
Hi All,
Just today, I had the A/C fuse blow out on the car. The fan blows fine even with the blown fuse. I replaced it with the correct fuse and within five minutes, it blew again!
If anyone has some insight, it would be very much appreciated.
Old Sep 22, 2002 | 12:07 AM
mjfox's Avatar
mjfox
Default Re: A/C Fuse Keeps Going Out (Ricks1989Roadster)
i would bet on the compressor clutch
Old Sep 22, 2002 | 01:46 AM
Ricks1989Roadster
Default Re: A/C Fuse Keeps Going Out (mjfox)
Compressor and clutch are less than six months old. Could it be anything else? I'm not too worried since the unit has a lifetime warrenty.
Old Sep 22, 2002 | 01:56 AM
jfb's Avatar
jfb
Disconnect the diode across the compressor clutch and see if your fuse lasts . If not, it is the electric clutch drawing excessive current and needs to be replaced.
Old Sep 22, 2002 | 02:56 AM
Rich_01659's Avatar
Rich_01659
Default Re: A/C Fuse Keeps Going Out (jfb)
could be running an excessively high head pressure. could be caused by 2 things. 1) the condensor is dirty/plugged or 2)the whole system is over charged. who recharged your AC last?
To A/C Fuse Keeps Going Out
