Reinstall Knock Sensors
Old Jan 30, 2017 | 10:44 AM
mixalive's Avatar
mixalive
Default Reinstall Knock Sensors
92 LT1 with 145K. I am reinstalling my knock sensors after a coolant change. There is not any sealant left on the threads and am requesting information on the proper reinstallation.
Old Jan 30, 2017 | 11:00 AM
JimLentz's Avatar
JimLentz
FSM says not to add sealant.
Old Jan 30, 2017 | 12:01 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
News ones have sealant/coating already in place on threads.
It's the reddish stuff, not sure what.
Old Jan 30, 2017 | 12:29 PM
383vett's Avatar
383vett
If reinstalling old knock sensors, just use liquid teflon pipe seal around the threads. I think 25ft/lbs is the correct torque but need to verify. You don't need to overcrank.
Old Jan 30, 2017 | 12:40 PM
DGXR's Avatar
DGXR
Teflon tape will be effective in sealing in the coolant, but I have heard many other members state that teflon tape can also insulate the KS from the block and cause functionality issues.
Myself, I used a *very small amount* of copper anti-seize on the threads. The copper will actually enhance the connection for good KS function, and I have not had any leaks.
The torque is 14 ft-lb. Anti-seize lubricates the threads and less torque is required, maybe 10% less ??? I'm not sure exactly. I applied 13 ft-lb because of the small bit of anti-seize. Just be careful.
Old Jan 30, 2017 | 03:22 PM
383vett's Avatar
383vett
If this is response to my thread, notice I did say "liquid teflon pipe seal". It comes out of a tube. I use it for all my sensors.
Old Jan 30, 2017 | 03:50 PM
DGXR's Avatar
DGXR
You, sir, are correct. I guess whenever I see the word "teflon" in reference to pipe threads, I immediately think of the tape. Thanks for the correction, and for the clarification on good products to use in this application
Old Jan 30, 2017 | 04:19 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i used white pipe dope on my 85 and it worked great.
Old Jan 30, 2017 | 05:53 PM
WW7's Avatar
WW7
If you get "sensor safe" sealant you won't have any problems with the sensor not grounding , this sealant is made for sensors.. You also have to torque the sensor correctly, if you don't " torque to spec" you can get false readings that will pull timing when it doesn't need to be pulled...I had this problem when I over torqued my knock sensor years ago...WW
Old Jan 30, 2017 | 07:30 PM
arbee's Avatar
arbee
"Sensor safe" deals primarily with silicon sealants and their effects on O2 sensors.
antfarmer2's Avatar
antfarmer2
I put in new they have the proper dope on them and just could not put back old ****. But sensor safe dope will work 14lb is the right toruqe and important the new dope will make you over toruqed.
Old Jan 30, 2017 | 07:33 PM
antfarmer2's Avatar
antfarmer2
Old Jan 30, 2017 | 09:10 PM
arbee's Avatar
arbee
Originally Posted by antfarmer2
Explain how this is wrong.
Old Jan 30, 2017 | 09:11 PM
arbee's Avatar
arbee
And you have the nerve to accuse other people of trolling you!!
Old Jan 30, 2017 | 09:54 PM
mixalive's Avatar
mixalive
Wow. Just the responses i was looking for. Thanks
To Reinstall Knock Sensors
