1984 digital tach problem
Old Sep 22, 2002 | 02:00 PM
bwalker1947's Avatar
bwalker1947
Default 1984 digital tach problem
I have a tach with all the lights lit up all the time , except a few down near zero. and no digital read-out. On the coil side tach.wire (wht) it has a couple connectors . now should this wire coming from the filter have the other end plugged into the harness , or should the harness be plugged into the other end of the filter? right now there is nothing plugged into to back end of the filter. all I can see from the books is that there should be a wire ( wht) coming from the coil to the filter then from filter to the harness which goes to the engine bulkhead then the cluster. any ideas here ? feel real dumb on this one
Old Sep 22, 2002 | 02:16 PM
JonM's Avatar
JonM
Default Re: 1984 digital tach problem (bwalker1947)
This should help you ...BTW...the filter isn't really needed...
Other sites that may help...
ClickHere
And Here
[Modified by JonM, 1:20 PM 9/22/2002]
