85 burn off module fix?
Old Sep 22, 2002 | 03:22 PM
GRX's Avatar
GRX
Default 85 burn off module fix?
Not that its happened to me yet, but, when my 85 burn off module goes kaput, I'm thinking that the portion that fails, are probably the contacts. Odds are, that the logic portion will last a long time. Why not 'tap into' the module and wire up a heavy duty relay? Seems TOO EASY to me though. ANYBODY have suggestions on the feasability/limitations of such an idea? Why pay the insane price for a new unit if only the contacts are toast? :smash:
Old Sep 23, 2002 | 08:26 PM
GRX's Avatar
GRX
Default Re: 85 burn off module fix? (GRX)
ttt
Old Sep 27, 2002 | 01:48 PM
want2drivemy85's Avatar
want2drivemy85
Hmm, very good question. I haven't heard of a service for fixing these things. But i'm sure someone with the proper knowledge might make a few bucks rebuilding/refurbishing the units.
Old Sep 27, 2002 | 08:04 PM
HighHopes85's Avatar
HighHopes85
Crack open the casing (actually, you bend some tabs and slide it out) and you will notice that it would be super-simple to fix. That is if you know what part needs to be fixed.
The entire board is old-school circuitry...no thin-film stuff going on--which should simplify the rebuilding process. I wouldda rebuilt mine but electricity and I get along like MGD and Cuervo. Great by themselves, but when you mix... :U
Edit--The other good news is that with the style of potting compound/circuit protector that they used, if a part fries itself, you can usually see the stuff bubble away. I had some good pics of mine, but they got lost on the net :confused:
[Modified by HighHopes85, 6:06 PM 9/27/2002]
To 85 burn off module fix?
