interior lights
Old Feb 3, 2017 | 04:42 PM
jasonmntc's Avatar
jasonmntc
2nd Gear
Default interior lights
I have a 1993 vette and the doors lights stopped working . The fuse is fine , i Have changed both door pin switches . They do not come when the doors are opened or if you use the headlight switch . I also have changed the bulbs. The strange thing is that i'm getting power with a test light on both sides of the bulb but the bulbs aren't lit. Help !!
Old Feb 3, 2017 | 05:21 PM
antfarmer2's Avatar
antfarmer2
Are you sure you have power and just don't have them shut off by the headlight switch?
Old Feb 3, 2017 | 05:53 PM
alexm1994's Avatar
alexm1994
I had a 93 at work that would not turn on the interior lights with the doors but would work from the headlamp switch. Replaced the interior lamp/courtesy relay underneath the passenger side dash panel and it fixed it.
Old Feb 3, 2017 | 08:07 PM
WVZR-1's Avatar
WVZR-1
I believe that the OP needs to mention which bulbs in the door!!!
OP - are you talking about the 212-2 bulb or the 73 bulb in the door You only mention the doors. Do the foot-well lamps work?
To interior lights
