A.I.R. "Control" and "Switching" valves...
Old Feb 11, 2017 | 11:52 PM
Tod Stiles's Avatar
Tod Stiles
Originally Posted by racerseks
No problem at all. That's good to know. I did find the entire valve with solenoid that looks exactly right, but haven't gotten the part number from the person that his it yet.
Yea, they are pricey on there.
Thanks...Yes, I "need" the solenoid, but I guess I was expecting to have to buy the whole valve...but if I can modify a solenoid off of something to work, I am fine with that.
I guess that's where the confusion was. You were thinking solenoid only, and I was thinking the whole valve. Sorry about that.
Thank you!
Well this is just me, but at this point I'd look a bit more and probably end up buying the cheapest new one I could find and get the solenoid off it if I couldn't get the whole valve to work. Of course I'm assuming the valve itself is OK. Like I said that's just what I would consider.
Old Feb 11, 2017 | 11:56 PM
racerseks's Avatar
racerseks
Yea, I can get this one that looks to be correct for $40-$50 for the whole valve...so considering doing that, as I don't know if the valve on the car is still okay or not. Thanks!
Old Feb 12, 2017 | 12:02 AM
Tod Stiles's Avatar
Tod Stiles
Don't forget about the electrical connector! Need to check that if you can.
Old Feb 12, 2017 | 12:04 AM
racerseks's Avatar
racerseks
Good point! I could go outside again...but do you mean the two pin connector, or is there something I am overlooking? Thanks!
Old Feb 12, 2017 | 12:08 AM
Tod Stiles's Avatar
Tod Stiles
Yep the two pin connector
Old Feb 12, 2017 | 12:09 AM
racerseks's Avatar
racerseks
I'll keep an eye out for it. Don't see it in the pics...but looks identical otherwise. Thanks!
