Antenna help
Old Sep 23, 2002 | 12:49 PM
brookman's Avatar
brookman
Default Antenna help
1988 vette. The guy that had it before me dropped in a replacement. I stops about 6 in. before it should going down, I disassembled the antenna gear box. There was about a foot of broken cord. I removed it and bottomed out the antenna. now it pops out the top. How do I set the limits?
Old Sep 23, 2002 | 02:09 PM
JonM's Avatar
JonM
Default Re: Antenna help (brookman)
http://www.madvet.com/pdf/601240.pdf
Old Sep 23, 2002 | 02:16 PM
jiml94's Avatar
jiml94
If you read the installation instructions which were provided above, you may have left the spring sleeve off before putting the holding cap back on. That thin brass? sleeve with the forks pointing up keeps the mast from coming back out. Just my guess.
Old Sep 23, 2002 | 02:22 PM
brookman's Avatar
brookman
Default Re: Antenna help (jiml94)
How does the antenna motor know when it is all the way up?
Old Sep 23, 2002 | 07:45 PM
r_hinks's Avatar
r_hinks
There are no limit switches. THere is a retaining nut on top of the antenna mast. Sounds like it is missing.
Old Sep 24, 2002 | 07:46 AM
Sam Lam's Avatar
Sam Lam
Did you install the antenna cord while the unit was disassembled or did you "feed in the cord" after the motor unit was assembled in the car?
To Antenna help
