shocks for '85
Old Feb 15, 2017 | 06:58 AM
sb66's Avatar
sb66
Default shocks for '85
hey everyone
I am looking to get new shocks for my 1985 standard and was hoping to find some opinions to help with the purchase - it will only be used on the street as at least for now - I do not have any track ambitions
there seems to be quite a range from billsteins, kyb, gm's own. currently I noticed the po put on Monroe -
I know it's a vette and I want it to act like one - but I also know that I do not want to break the bank and gt racing is not calling my name
does any of that make sense?
any help would be greatly appreciated
thanks
Sean
Old Feb 15, 2017 | 09:36 AM
aklim's Avatar
aklim
I like Bilstien because of their policy of giving you a new shock and not asking too many questions. Several toimes they have done just that for me. No questions asked.
Old Feb 15, 2017 | 09:54 AM
OldGyrene's Avatar
OldGyrene
I went with the KYBs for my '85. Made a real difference and priced well. Fronts: KG4537, rear: KG5564.
Old Feb 15, 2017 | 11:30 AM
sb66's Avatar
sb66
when they gave a new one was it a construction issue or worn out - they are rebuildable also?
thanks
Old Feb 15, 2017 | 11:31 AM
sb66's Avatar
sb66
I do really like the price for these - I used these before on a Porsche 924 that I had and they worked nicely for me then
thanks
Old Feb 15, 2017 | 11:34 AM
sb66's Avatar
sb66
does anyone know what the ride difference would be between these or others?
I am sure some are firmer than others - there does tend to be a fair difference in price with some - not that that is the only factor -
as most people want the best part at best price for your application
Old Feb 15, 2017 | 11:48 AM
aklim's Avatar
aklim
thanks
One got oil fumes sprayed on it. Crank case entrance fumes ate up the seals. 2 front ones on the vette was from old age. They sent new ones after the old arrives
Old Feb 15, 2017 | 01:01 PM
sb66's Avatar
sb66
that's pretty damn good
Old Feb 15, 2017 | 02:28 PM
vader86's Avatar
vader86
I had Bilsteins in the past, they ride firm. My KYBs are softer and more for spirited cruising than racing. Koni adjustables can do both.
I'd recommend Bilstein however.
Old Feb 15, 2017 | 06:35 PM
383tpimachine's Avatar
383tpimachine
Had konis. loved them when they were on.
Old Feb 15, 2017 | 06:48 PM
sb66's Avatar
sb66
thanks
just curious- you are using kyb's now? why still recommend bilstein?
Old Feb 15, 2017 | 06:49 PM
aklim's Avatar
aklim
Considering it was my fault that oil fumes were blowing on it and the idea that the vette shocks were 10 years old. I'd say. 1 vette shock was leaking and they had me send both for a look see. I think they didn't do anything. Within 2 hours of the arrival, there was a new box on the way to me. I doubt they checked anything other than to replace what was there with new ones
Old Feb 15, 2017 | 06:51 PM
aklim's Avatar
aklim
thanks
My shocks are 200 apiece since they are FX3. They warranty for life, no questions asked.
Old Feb 15, 2017 | 08:14 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
C4's are noted for their ride being a touch harsh. The later years softened up the spring rates that took the edge off when cruising. The earlier years have higher spring rates. Using cheap KYBs and the like will not match well (dampen) with these springs.
Bilsteins had properly matched their valving to work with these spring rates to offer a good compromise of handling and ride. No "racing" or "track" options. Just good overall performance.
Old Feb 16, 2017 | 06:59 AM
kenmohr's Avatar
kenmohr
Bilsteins
Old Feb 16, 2017 | 11:40 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
can we get a model or part number for the bilsteins? thnx.
Old Feb 16, 2017 | 11:41 AM
vader86's Avatar
vader86
thanks
Yes i'm not totally happy with the road feel of the KYBs and will go back to Bilstein when these wear out.
To shocks for '85
Old Feb 16, 2017 | 12:24 PM
sb66's Avatar
sb66
I was looking at summit racing - these are the part numbers the site search gave - though I would double check
24002288 and 24192927. Bilstein B6 Performance Series Shocks and Struts (?)
Sean
Old Feb 16, 2017 | 10:26 PM
sb66's Avatar
sb66
Sean
anyone else confirm?
Old Feb 17, 2017 | 08:40 AM
sb66's Avatar
sb66
bilstein online catalog search for b6 models - 24-192927 rear. 24-02288 front
