Driveshaft loop.
Old Sep 23, 2002 | 04:13 PM
scorp508's Avatar
scorp508
Default Driveshaft loop.
I have my torque beam measured to where 6" from the rear of the tranny is. Question is where on the loop should this be in refernce to? In the center? The front edge of the loop? The back edge of the loop?
Thanks. :cheers:
Old Sep 23, 2002 | 04:30 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Driveshaft loop. (scorp508)
Scorp,
I have often wondered about the loop on a vette. How the heck do you install it. Everything is already in the torque beam. Can you post some picts of this.....I will soon need one and have even been checked at the tracks. I told them about the torque beam and they dismissed the loop???
Thanks :cheers:
Old Sep 23, 2002 | 04:32 PM
scorp508's Avatar
scorp508
You just add a piece of metal that finishes the circle of the torque beam. You actually use 1/2 of a lakewood kit.
Old Sep 23, 2002 | 05:15 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Here is my page on when I did it back in December.
http://users3.ev1.net/~vettefolk/122...shaft_loop.htm
Old Sep 23, 2002 | 05:50 PM
J Z06's Avatar
J Z06
Default Driveshaft Loop
Chris
thanks for sharing those. I am planning on something similar over the winter. It'd be safe to say, the C beam would prolly contain the driveshaft in the event of an incident. I'd rather be safe than sorry though.
Old Sep 24, 2002 | 03:25 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Driveshaft Loop (JD 90 383)
Chris
I dunno, if the shaft did come loose and kicked to the right of the car the first thing it is likely to hit is the fibreglass/plastic tunnel floor... :eek:
Old Sep 24, 2002 | 11:34 AM
1991Z07's Avatar
1991Z07
ZFDoc also has one of these on his site at http://www.zfdoc.com/c4SafetyLoop.htm
Looks like it works good too.
To Driveshaft loop.
