Wet feet
Old Sep 23, 2002 | 04:59 PM
C1C2C4's Avatar
C1C2C4
Default Wet feet
Has anbody had this problem? When I make a hard right turn a stream of water pours out of the center console (the heater ducts). The water is clear, not antifreeze. Had the AC on. Figured that the drain in the evaporator box was clogged, check and it appears open. Any other ideas.
Old Sep 23, 2002 | 11:34 PM
bogus's Avatar
bogus
Default Re: Wet feet (C1C2C4)
it has to be the drain... make sure it is clear at both ends. run a coat hanger up the line... or use some compressed air.
Old Sep 24, 2002 | 11:05 AM
C1C2C4's Avatar
C1C2C4
Default Re: Wet feet (bogus)
Thanks for the reply. What do you mean, both ends, I only checked the drain hole at the bottom of the evaporator case on the firewall. I was afraid to poke a hanger in there for fear of damaging the core. Any ideas
Old Sep 24, 2002 | 12:35 PM
vettmech's Avatar
vettmech
You might also try taking out the blower motor and seeing if you can find a bunch of crud in there :seeya
To Wet feet
