93 corvette wont start
Old Feb 19, 2017 | 07:25 PM
ethangro1's Avatar
ethangro1
4th Gear
Default 93 corvette wont start
ive got a 93 corvette that will only run for a couple of seconds with starting fluid then quit i have put a new fuel pump in and it still wont run.i have brought the codes on the dash and they were h25 h62 and h83 what are these codes and has anybody had a similar issue?
Old Feb 19, 2017 | 07:57 PM
93Rubie's Avatar
93Rubie
Do you have fuel pressure with the key on, engine off? Pump should run for about 2 seconds when key is turned on.
Old Feb 19, 2017 | 09:21 PM
ethangro1's Avatar
ethangro1
4th Gear
yea I can hear the pump run for a couple seconds
Old Feb 19, 2017 | 10:20 PM
aboatguy's Avatar
aboatguy
Did you run "noid light' to see if the ecm was trying to pulse your injectors (the noid light kit is pretty cheap or autozone probably will loan it to you
Old Feb 19, 2017 | 11:01 PM
ethangro1's Avatar
ethangro1
4th Gear
no I haven't I will try that
Old Feb 20, 2017 | 04:48 PM
aboatguy's Avatar
aboatguy
if you have fuel pressure and spark, if the injector fuses aren't blown and the noid doesn't pulse...it starts to narrow down the suspects!
That's whats great about the C4 it is still a pretty basic platform. Spark, Fuel, Air, should = press, bang, blow.....
You never answered if you had fuel pressure? ... if your fuel pressure regulator failed it probably won't run
Old Feb 22, 2017 | 04:37 PM
ethangro1's Avatar
ethangro1
4th Gear
I need the gage to check so I'm not sure gonna do that today
To 93 corvette wont start
