So, I'm considering (eventually) doing a 383 stroker build on my '87 coupe. Just doing research for now, but here's the list of parts I'm looking at, based on what I've been reading here and on the "third gen" forum:
FAST ez-EFI 2.0 retro system
FIRST fuel injections TPI style manifold
FAST dual sync distributor
SCAT forged 383 rotating assembly
AFR 195cc SBC Eliminator Street Heads 1041
Comp cams Xtreme Fuel Injection 268XFI HR13 OR Thumpr™ 283THR7
Comp 1.52:1 rollers
Melrose headers
Looking for 450 - 500 HP at the crank. Think this will get me there?
Also, thinking I'll be spreading this out over a 3-4 year span for the sake of my budget, and hoping to do most of the work myself while I'm storing it for the winter. With that in mind, I'm thinking about doing it in stages:
1)Computer and distributor
2)Intake and exhaust
3)Heads and rockers
4)Short-block and cam
Would that make sense (besides having to remove things repeatedly like the exhaust...)?
Thanks in advance!
Sounds like a well thought out plan for parts.You should get at a minimum 450 crank horsepower.You left out what size injectors that you plan on putting in.
Haven't looked into them that much yet. Because the manifold needs a different fuel rail, it comes with the rail and up to 30 lb injectors at no additional cost, but I've seen several builds with 36's , and even one with 42's.
I'm leaning toward 36's, but wonder if the 30's would be enough?
personally, I'd do it in reverse order (more or less); get a bare block and do the short block build up first...then maybe heads and have at least a short block, or better yet a long block ready to drop in.
a lot of the stuff is gonna be repeated if you build it according to your plan...more time, duplicated effort, costs, etc.
if you do the engine (and as much of it that can bolt up to it), first, your car stays running with minimum downtime.
also the engine will be the most expensive part, but the engine build can be accomplished over time in discrete incremental steps with the least damage to your short term finances.
One thing missing from your plan, anytime you start mixing and matching aftermarket parts, the lower end should be balanced as a unit: flywheel (or flex plate), crank, rods, pistons, rings, bearings, harmonic balancer
I would love to do it that way, but being that this will be my first build, part of my reason for doing it backwards is to learn how. I tend to learn best by tearing things apart first then putting them back together, lol.
Curious as to what I'd be looking at in repeat costs though?
As far as downtime goes, I have automatic downtime in the form of Michigan winters, so 3-4 months per year of not driving it is a part of life anyway... :/
Perhaps you could fill in some of the blanks for me on the lower end balancing you described? Like I said, very new to this, so the more details I can wrap my head around on the front end, the better...
Just did a quick look on TPIS' website, and they recommend 30 lb/hr injectors for the power range I'm looking to make. Is there a reason I'm seeing a lot of people going with 36’s instead? Durability, future upgrades, etc?
Too many folks get the biggest injectors they can find thinking it will make more power. Not always a wise choice.
There are charts out there giving you a guide based on Cubic inch and other factors.
Really need to talk to a fuel injector specialist before you finally decide, if youre doing the tuning yourself. Otherwise I'd recommend you speak to your tuner as well.
[QUOTE=87c4z52;1594150979]So, I'm considering (eventually) doing a 383 stroker build on my '87 coupe. Just doing research for now, but here's the list of parts I'm looking at, based on what I've been reading here and on the "third gen" forum:
Comp 1.52:1 rollers
Melrose headers
3)Heads and rockers
Thanks in advance![/QUOTE Look into Skip White Performance 383 Super Stroker stg 2, base engine. They will sell it less the intake, and for the money it's a hell of a deal. I just installed one, so far so good.
I'm hoping to do it myself, hence the FAST ez-EFI. Any recommendations on who I could talk to?
Hoping to tune it myself, hence the ez-EFI. Any recommendations on who to talk to?
Hoping to do most of the build myself, except for boring out the block. But I'll check into it anyway. Thanks!
If you are going to purchase and install a new intake, I would recommend against a TPI style intake. The long runners of the TPI style will limit your useful powerband to 5000rpm and below, no matter how large the runners' cross section is. You'd have a much wider powerband and make a lot more power with a short-runner LTx-style intake. Otherwise, you will give away a minimum of 30hp and probably more like 50hp with that TPI intake. This is especially true if you build the engine with a short-runner intake in mind from the get-go, as you'd be able to use significantly more compression ratio and more cam overlap without inviting knock at the TPI's resonance-induced peak cylinder pressure.
With the LTx intake you gain horsepower but loose a lot of torque.
Sigh...Two responses to this:
1) You don't actually lose torque; the 1990 L98 was rated at 350lb/ft and the 1995 LT1 was rated at 340lb/ft, so there is no significant difference in peak torque. But you do get to shift up higher and get a much flatter torque curve. That's why you get a much wider usable power band and way more power.
2) Torque at the crankshaft is irrelevant to how fast your car accelerates. Power is the one and only measure that predicts the performance of your car. If you want to accelerate faster you always opt for higher power. And if you can get more power and a wider, more usable power band, it's a no-brainer.
While I've heard that argument a lot my reference point and the build I'm basing mine off of is this... http://www.superchevy.com/how-to/eng...tpi-induction/
450-ish CHP, and it carried out all the way to 6000 RPM. Sounds pretty good to me. Also, they used the stock upper and lower portions of the manifold, with big runners, and ported everything out, flowing up to 260 cfm, whereas the FIRST manifold flows 300+ cfm out of the box, and can be ported farther still...
For what it's worth, I like the look of the engine with the TPI, and I like the way the power band feels. I just want more of it...
This is not set in stone either, just a guide. I run 24lb. Injectors in my 355 with 350 rwhp. I have 0 fuel delivery issues. Get an adjustable fuel pressure regulator too.
Dont even bother my friend. The torque monster theory that prevails out there with these outdated TPI systems is here to stay. I with others have posted graphs showing the torque and power gains of aftermarket intakes with shorter runners but it doesn't matter to some.
