Ok guys, I need some help here. I have converted my l98 to a lt1. I changed the intake and heads. I have the mods done to both intake and heads. I purchased my remote thermostat housing and now I am unsure of the connections. I want to make sure I have coolant where it is supposed to be. Should a hose run from the remote housing to front of intake and one each to the front of the heads? Please help. Thanks
What intake is on the car? You need water from each head to flow into the bottom of the remote thermostat and them a hose from the upper part of the housing to the radiator. Just like the original SBC intake, the only difference is you have a remote T-stat housing.
a basic difference between the l98 and lt1 engine block is that the lt1 has a cast in blockage that forces the cool water from the water pump up into the heads before the water returns to the engine block...exact opposite of an l98
so while LT heads and intake will bolt onto a l98 block, in no way can you "convert" an l98 to an lt1
you can replace an l98 engine with an lt1 engine, but "convert" one to the other ?
Looks like you will be "converting" the cooling system as well
The heads and intake from an LT1 can be modified to work on a L98 but usually the work and cost involved to do this does not pay off vs the gains you get in performance. With that being said the OP mentioned that he has already converted the heads and intake to work on a L98 so he needs to plumb the remote T-stat to make this work.
I had the heads welded at a machine shop and decked to allow for the conversion.
I ran a hose from the front of each head to the remote housing. I also have the throttle body running through the remote housing with the temperature sensor from the tpi intake installed in the housing. Does this sound right? I am having problems finding a great spot to mount it to keep it below the radiator cap and still have room. Thanks
Take a look at these pictures of the set-up I used when i had the LT1 intake on my 406. This set-up worked fine, make sure you drill an 1/8 hole in the T-stat to make sure you have water flow while the engine is warming up so the T-stat can warm up.
Exactly what I was looking for! Many Thanks to you.
No problem! Just to help someone else if they are thinking of doing this. When I started I done lots of research and thought this could be something I could do verses a mini ram and save some $. Well, at first I was saving money, but it seems every time you put something on the car there is something I have to buy to make it work. All this was not included in my research. Things such as the air pump hits the throttle body now I have to install air pump delete bracket. I really did not want to do that, my advice NOW buy a miniram.
That was my conclusion in the end also, buy the time I did all the work and bought all the parts I may have saved a few hundred dollars but it would have been so much easier to buy the mini ram. If I paid myself for the labor, I was making $1 per hour.
