Harmonic Balancer size???
Old Sep 24, 2002 | 04:30 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Harmonic Balancer size???
Is the harmonic balancer 6.75" or 8.00" on a 1984 corvette.....can anyone help???????
thanks
tony :confused: :confused: :confused:
Old Sep 24, 2002 | 04:39 AM
gtsyellow's Avatar
gtsyellow
Default Re: Harmonic Balancer size??? (oldace84)
6-3/4" are the standard L98 size, 8" will hit the rail
Old Sep 24, 2002 | 04:50 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Harmonic Balancer size??? (gtsyellow)
84's dont have an L98 but it should be 6-3/4 as mentioned.Even this size is close to the frame.
If in doubt,use a measure tape.Take off the pulley and measure it across.
Btw,If you need a new balancer,dont just buy any for your car.Make sure its for your particular year...many catalog companies sell new balancers but the timing mark and keyway may differ.
That was the case for my 86...Even GM performance parts sold balancers for 350 engines but the timing line was different on my car and I had to pay more.I couldnt use their advertised balancer for SBC 350's.
Old Sep 24, 2002 | 11:07 AM
Corvette0096's Avatar
Corvette0096
!00% Right, I tried to install the one that came with the ZZ4 motor and it hit the core support.
Old Sep 24, 2002 | 11:33 AM
dtorc4's Avatar
dtorc4
Default Re: Harmonic Balancer size??? (Bill's86Coupe)
OMG. I did not know this. I am putting a whole new (non-Corvette) engine in. Will I still need a "Corvette only" balancer?? It is a 6 3/4" balancer, but it's nothing fancy. :cheers:
Old Sep 24, 2002 | 02:18 PM
Aggravated4life
Default Re: Harmonic Balancer size??? (dtorc4)
Dtor,
You should be fine with the balancer you have...when using another balancer and etc,just compare the timing mark to they keyway location on both balancers and make note of it.
That way you wont go crazy trying to time the engine again if needed during a tune up or something.Thats why i stated to get the same balancer if possible to avoid any problems.
Old Sep 24, 2002 | 11:19 PM
gtsyellow's Avatar
gtsyellow
i hope the engine was balanced with the balancer you have and the flywheel. you'll have a engine flying apart if it wasn't
To Harmonic Balancer size???
