Tranny slipping slightly HELP!!!!
Old Sep 24, 2002 | 01:42 PM
gmcoady's Avatar
gmcoady
7th Gear
Default Tranny slipping slightly HELP!!!!
Transmission slipping slightly on my '90 6-SPEED. From cruising in forth or fifth gear, it probably doesn't mater what gear, and I stomp on it there is an ever so slight rev and then it seems to catch. Could the Clutch be slipping or maybe low fluid in the Transmission? $$$$$$$
Thanks in advance. :confused:
Old Sep 24, 2002 | 02:11 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Tranny slipping slightly HELP!!!! (gmcoady)
Bad clutch. How many miles on 'er?
Old Sep 24, 2002 | 02:21 PM
Nathan Plemons's Avatar
Nathan Plemons
Low fluid in the tranny would just make it louder, more difficult to shift, and eventually fuse it into one solid chunk of metal. Sounds to me like your clutch is shot, sorry.
Old Sep 24, 2002 | 02:56 PM
gmcoady's Avatar
gmcoady
7th Gear
Default Re: Tranny slipping slightly HELP!!!! (92Shawnster)
There are about 70,000 miles on the car. Clutch has always been noisey. When the car warmed up the louder it seemed to get.
Old Sep 24, 2002 | 06:48 PM
T1Kilr's Avatar
T1Kilr
Its your clutch.... It will only slip worse from there... get it replaced before you start damaging the flywheel.
LUK clutch replacement kits run about $290 Flywheels (DM) about $600
To Tranny slipping slightly HELP!!!!
