1985 corvette
Old Sep 26, 2002 | 11:11 AM
vetracer's Avatar
vetracer
Default Re: 1985 corvette (fathermojo)
It won't do them any good to rip out the cylinder because the resistor value is sent to a module behind the dash. Until this module sees the correct resistance, the car will not start. You can do what you are suggesting, many corvette parts suppliers sell VATS bypass modules which plug in under the steering column. I replaced my ignition cyliner lock, and it wasn't that hard.
Old Sep 27, 2002 | 06:24 AM
fathermojo's Avatar
fathermojo
Default Re: 1985 corvette (vetracer)
do you know if the vats bypass module adds any parasitic drain to the battery? seems there's enough of that on the early c4s to begin with
