86 idle & distributor cap
Old Sep 24, 2002 | 04:27 PM
j.k.ritter's Avatar
j.k.ritter
Cruising
Default 86 idle & distributor cap
stock 86---when shifting from park to reverse idle holds 700rpms--when passing thru N to drive the rpms increase to 10-1100 and car jumps into gear. Also, on the last two distributor caps after 5-7000 miles ---the cone in the inside center where the carbon tip contacts the rotor -----the cone is worn down smooth to the top of the cap and the carbon tip is 1/8 inch in length. Any ideas as to what causes and what are the cures?
Old Sep 24, 2002 | 04:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 86 idle & distributor cap (j.k.ritter)
Not sure about the idle change; possible a little sticking in the IAC.
You should replace dist cap & rotor as a matched pair.
