tb bypass
Mar 7, 2017 | 11:29 AM
tb bypass
Need some help on how to route the right side hose's. I have a 96 upper hose for the left side. Just want a cleaner engine by. My car is a 92. Thanks
Mar 7, 2017 | 12:35 PM
On my 91, I just found a hose that worked. I put them together and a small pipe to hook them in right for a bit then took it out and mixed and matched at the auto parts store.
https://www.corvetteforum.com/forums...post1592452074
Mar 7, 2017 | 01:17 PM
St. Jude Donor '17-'18-'19-'20-'21-'22
Quote:
Originally Posted by
onDjuice
I saw this on Eckler's this morning. Might be what you are looking for.
http://www.ecklerscorvette.com/corve...FV62wAodj68NeA
Mar 7, 2017 | 01:19 PM
That link doesn't work but you can go to ecklers they have a throttle body bypass
Mar 7, 2017 | 02:11 PM
Thanks. I'm trying to get rid of both hoses on either side of the motor..
Mar 7, 2017 | 07:15 PM
I just got a long enough length of heater hose to route directly from the heater core to the intake. No splices required.
Mar 7, 2017 | 07:56 PM
I'll have to check it out on my car..
Mar 11, 2017 | 07:32 PM
[QUOTE=TA;1594249465]I just got a long enough length of heater hose to route directly from the heater core to the intake. No splices required.
[/QUO
Ok i got the hose off the right side of the tb that goes to the heater core.
Now were do i connect that hose to. Or do i get rid of it. Thanks
Mar 12, 2017 | 10:48 AM
[QUOTE=onDjuice;1594278948]
[/QUO
The hose originally goes from the heater core to the TB and second hose from the TB to the intake manifold. You have to either unconnect the hoses to either side of the TB and use some type of connector to splice them or get a long enough length of heater hose to route directly from the heater core to the intake.
Mar 12, 2017 | 11:03 AM
My car is a 92. I have 2 hoses on the right side one to the tb and one to the thermo housing. No hose to the intake..
Apr 2, 2017 | 08:17 AM
I would really like to clean up the engine bay. Getting rid of the 2 tb hoses would be nice.
My car is a 92 with a one year water pump style i think..
Apr 2, 2017 | 10:33 AM
onDjuice
I don't know that you can get rid of them all together. You still need coolant to flow through them. Your engine will thank you for it.
