'92 LCD dash display
Old Mar 8, 2017 | 05:47 PM
sailorsteve's Avatar
sailorsteve
Default '92 LCD dash display
The orange LCD display has developed some erratic behavior- sometimes it works normally (usually on cold startup) and other times the display gets dim enough to be barely legible. Sometimes it recovers by itself while driving but other times not until the next cold startup, when it always seems to be ok for a while.
This is the second version of the LCD dash. I know the original ones were more likely to be a problem but I understand the newer ones act up too. This time, my go-to source, the FSM, doesn't address the issue. I'll be checking the G201 ground before I go for LCD module repair, just curious what others have found with an intermittent condition like this.
Old Mar 8, 2017 | 07:38 PM
superdave269's Avatar
superdave269
Please post your findings. My 92's dash has had a similar problem since I bought it. My dash blinks if you will. It doesn't actually go dark but the brightness increases and decreases all the time. It kinda flickers. I have never really gotten used to it. It drives me a little crazy.
Old Mar 8, 2017 | 10:38 PM
Mayor111's Avatar
Mayor111
Does this help?
Old Mar 9, 2017 | 10:47 AM
sailorsteve
Originally Posted by Mayor111
Thanks for that- I'd like to get a better handle on diagnosis before I get into the module itself, but if I do open it this is a good tutorial.
Old Mar 9, 2017 | 02:33 PM
belairbrian's Avatar
belairbrian
Mine blanks out on occasion
a smack above it on the dash brings it back
considering the cost of having batee overhaul it I think I'll just ship it off
it were just bulbs id fix it myself but it's not in my case
Old Mar 18, 2017 | 07:29 AM
krackenvette's Avatar
krackenvette
Where can you ship it off to get it fixed? Mine is slowly getting dimmer.
Old Mar 18, 2017 | 09:52 AM
belairbrian
Batee has a good reputation here on the forum. For what they are doing the prices seem fair.
http://batee.com/
To '92 LCD dash display
