LT1 and L98 engine compatibility
Mar 9, 2017 | 11:49 AM
1st Gear
Do LT1 engine parts fit L98 engines?
Mar 9, 2017 | 02:36 PM
St. Jude Donor '05
Use Gen 1 stuff if you have an L98 or LT parts if you have a 92 up not worth the work/$ youll have to part with.
Mar 9, 2017 | 02:57 PM
Quote:
Originally Posted by
DGKROCKSTAR
Oil Pan, Valve Covers and Exhaust Manifolds and throttle body will fit.
Camshaft (push in pin), lifters, pushrods, rocker arms, valves and valve springs will fit
Crank, Rod and Pistons will fit.
Block / Heads / Intake (without modification) will not
