Question for the Supercharged Peeps
If you want an I/C I have one with all the piping/hoses. PM me if interested.
Steve
OP - unless your running 8 LBS of boost or above I wouldn't bother with an intercooler. I would add meth injection to your set up if you want some added safety. Some here are running meth without an intercooler. I plan on running both in the future.
My intercooler is from Procharger. I originally purchased a complete Procharger kit and have replaced or upgraded most of it with help from Blowerworks. I tried getting the AC to fit when I first installed my kit but decided to delete it. I would have had to charge it many times over by now.
Using my photo is not a representation of an off the shelf kit. I've used different vendors and replaced most of the stock parts. Some fabrication has been necessary to make it clean, function, reliable and fast
. I'm currently rerouting the intake air to the SC and some of the coolant hoses. The one above the SC inlet will be ran differently. I've found out that if you change one thing it usually affects at least one other thing. So, make a plan if you really want to change things around.
Good luck on whatever you choose.
Last edited by armysnipe; Mar 13, 2017 at 10:48 PM. Reason: add pertinent information
Is the kit made specifically for the C4? I was looking at intercooling and meth injection. My brother has both. But his build is much more involved than mine. C5Z with 705rwhp. Does the meth cool the charge enough to eliminate the intercooling?
Depending on how much boost you make-The Meth may be all you need. From what I have seen at the racetrack-People making over 20lbs of boost use both I/C with Meth. I have also seen at the racetrack someone with a C5 making over 20 lbs of boost with e85, meth, and I/C. To be clear I am new to this too. As I have posted-I will be running mine of e85 and no I/C and no meth.
Forum member Dizwiz is running meth with no I/C on gasoline with great results.
If you are interested in mine I would like to get $200 plus shipping.
Steve
Thanks for the pic. Exactly what I was looking for. I don't want to lose my AC it's too damn hot in Texas for that lol. Was it that much a pain in **** trying to get it to fit with AC?
Steve
Ok I'll let you know. I have to install a boost gauge to see what I'm running now and decide if I want to go higher. Hoping to do that this weekend. Surely don't want to mess with my AC like he did it's too dang hot in Texas lol.
Thanks.
I ditched the AC once I went above the base design of Prochargers kit. It was in my way, LOL!. Anytime I had to work on the supercharging system I had to remove the AC components.
AC would definitely be a priority in TX.
As mentioned your boost level will dictate your decisions and change the overall design.
I'm up to 13LBS and will probably leave it there. I'm still running the stock crank with all forged components minus the crankshaft. My goal is fast and reliable. One regret is not getting a forged crank.
i have the same air intake piece you have but i have a meth bung (from blowerworks), welded into it.
i store 4 gallons meth/water in the rear of the
car so i am not worried about running out .
i also have my compression dropped down to 9.7:1 static
thru use of
bigger cc afr heads.
stock bottom end entirely and it made 520 rwhp at 6000 rpm - which is all the higher i could spin on the dyno before my appt was over.
Steve
I run 93+meth with a big A2A IC all custom.
Going to run e85 on top of the other two coolers.
I used deka 80s for 700rwhp. They are good for 850ish @ 58psi fuel pressure.
Nice setup.
/QUOTE]I follow your build thread-
Do you think it's a problem with only 8Lbs of boost? As I stated in this thread-I see people at the track run e85 and no I/C. For now I am only looking to make 100-150 extra HP.
Thanks for your input.
Steve
Jim
are you using that custom IC in conjunction with a stock radiator or did you need to use an aftermaket radiator (or modify the position) of your stock radiator?
does this all fit under the stock radiator shrouding or did you remove that?
how are your coolant temps with that setup?
ive heard some say its bad to block the radiator with an intercooler...?
is that myth or urban legend ?
