Identifying Pistons
Old Sep 24, 2002 | 11:50 PM
Langadorf's Avatar
Langadorf
Default Identifying Pistons
I'm trying to identify which brand pistons I have and what sorta specs they have. I think they might be TRWs but don't know for sure. The only marking I can see on the top of the pistons are the numbers L2491. There are also some smaller numbers on them but they are different on every piston. The pistons are flat top with 2 valve reliefs. Any help would be appreciated.
Old Sep 25, 2002 | 12:27 AM
marlon88's Avatar
marlon88
Default Re: Identifying Pistons (Langadorf)
you got any pics of them ???
Old Sep 25, 2002 | 02:55 AM
sinistervette's Avatar
sinistervette
TRW # L2491 = 377- 4" bore X 3.750" stroke
383 - 4.030"bore X 3.750" stroke
388 - 4.060"bore X 3.750" stroke
1.430 compression distance
piston weight = std bore - 482+or- 4 grams
.030 bore - 497 +or- 4 grams
.060 bore - 512 +or- 4 grams
use with 5.7" rod, .020 deck clearance, .039 compressed head gasket thickness, compression ratio is as follows: 57cc combustion chamber=11.5
64cc chamber = 10.6
68cc chamber = 10.2
76cc chamber = 9.4
NOTES: A lightweight forged flat top/2 valve reliefs for 3 3/4" stroker using 400 crank. 2 valve reliefs = 3.4cc dish, wrist pins weigh 143 +or- 2 grams, either press fit or floaters.
You've got a very good, strong set of pistons, enjoy! :cheers:
Old Sep 25, 2002 | 03:23 AM
Langadorf's Avatar
Langadorf
Default Re: Identifying Pistons (sinistervette)
Thanks for the info!
To Identifying Pistons
