T56 adapter
Old Mar 18, 2017 | 08:45 PM
Cardshark613's Avatar
Cardshark613
1st Gear
Default T56 adapter
Tried searching, only found old discussions about pro street. Where can the t56 cbeam adapters be had these days?
Old Mar 20, 2017 | 02:02 PM
383tpimachine's Avatar
383tpimachine
Build your own.
Old Jul 10, 2017 | 02:06 AM
Karp's Avatar
Karp
Originally Posted by 383tpimachine
Build your own.
I know people have built them.
Does anyone have the template?
angles? measurments?
im getting serious about a 90 c4 conversion.
thanks to all.
Old Jul 10, 2017 | 08:40 AM
383tpimachine
thanks to all.
Everyone builds them slightly different. Mine has full gussets everywhere. 3/8in and 1/2in steel throughout. Others make it with aluminum or 1/4in stuff.
template is just fit it around and weld then test fit.
Old Dec 9, 2017 | 10:33 PM
Karp's Avatar
Karp
Aloha all,
So I will attempt to build on myself yet share my results/ dimensions to help others hopefully. These are my results your may be slightly different, use this as reference only.
NO measurements will be in pictures till the final fit to ensure erroneous info is not out there.
First draft of the C Beam piece.
First draft of the bottom plate.
Old Dec 9, 2017 | 10:40 PM
dclafleur's Avatar
dclafleur
need4speed069 built a few somewhat recently, you might reach out to him and see if he's still making them.
Old Dec 10, 2017 | 12:42 AM
mtwoolford's Avatar
mtwoolford
this is what real hot rodding is all about, making your own adapters to put two pieces together that were never intended to go together; good luck
To T56 adapter
