Question on the "Range" indicator on the dashboard...
Old Sep 25, 2002 | 06:20 PM
ladyinblack's Avatar
ladyinblack
St. Jude Donor '10
Default Question on the "Range" indicator on the dashboard...
While idling in the 7-11 parking lot for approximately 5 minutes, my range indicator went from 315 miles to 275. Is this normal? It went back up to around 298 when I starting driving it at normal speeds. I thought I was leaking gas, but didn't smell anything.
Thanks! :seeya
Old Sep 25, 2002 | 06:34 PM
Blue85L98's Avatar
Blue85L98
Cruise-In III Veteran
Default Re: Question on the "Range" indicator on the dashboard... (ladyinblack)
Yes, it is normal.... your range is constantly updated, and will change based on the current fuel usage versus speed(distance traveled vs. time). Since you are parked, speed and distance traveled are zero, but fuel is being used to keep engine running, the range will decrease until you start traveling again, where it will again continue to update based on those parameters. :cheers:
It does the same thing while you are stopped in traffic.
[Modified by Blue85L98, 2:37 PM 9/25/2002]
Old Sep 25, 2002 | 06:41 PM
vader86's Avatar
vader86
:yesnod: :yesnod: normal
Old Sep 25, 2002 | 07:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Of course it all depends on how you leave the 7-11 parking lot; my range indicator (and average mileage) usually drop till I hit highway speeds. :lol:
Old Sep 25, 2002 | 09:06 PM
bogus's Avatar
bogus
uh, the Range indicator has little to do with how far your really going to make it, tho... remember, it is dependant on the sender, and the sender has its own problems... such as the inability to tell you how much fuel you have left.
basically, it is neato... but rather useless.
Old Sep 25, 2002 | 10:17 PM
K87ZZ4's Avatar
K87ZZ4
Default Re: Question on the "Range" indicator on the dashboard... (bogus)
I totally agree about it being useless, unfortunately. It has the potential to actually be helpful, especially on road trips, but it's not. First off, it's only as accurate as your fuel gauge... and I have yet to meet a fuel gauge that actually shows half a tank when the tank is half full. I think that is the biggest source of the inaccuracy.
As far as I've figured out, it multiplies your current average MPG times the number of gallons it thinks you have in the tank and that's how far you should be able to go. The only problem is, most of the time, it thinks you have more gas than you actually do, so it tells you that you can go farther than you actually can :(
Old Sep 25, 2002 | 10:48 PM
vette92_1's Avatar
vette92_1
Default Re: Question on the "Range" indicator on the dashboard... (K87ZZ4)
Well Said :yesnod:
I've been debating on buying a new sending unit, but I am afread it will do the same thing after a short time, so that is 300.00 out the window.
Has anyone tried bending the float arm a little to compensate for the amount your gage is off?
To Question on the "Range" indicator on the dashboard...
