89 C4 No Heat/AC Climate Control, Or Windshied Wipers
I a new owner of a 89 C4.It has no climate control Heat or AC at all.No wind shield wipers at all.Any tips/ ideas where to start or what to do?Also some problems with power mirrors and seats.
Zen Vet Master Level VII
Clearly electrical issues. Start with fuses,
Can you give us a bit more history on the car? Has it been sitting? Did you do something that caused the problems? ETC....
Well, start with the fuses.
When you say "no climate" does ANYTHING happen? Vents move, blower motors work, no heat or AC air flow? PLease be more specific.
On the wiper, I'm not real sure on 89s but you may have a relay to check after the fuses.
Also, get yourself a Field Service Manual if you don't have one. It is filled with a step-by-step diagnostics
Got the windshield wipers working ,it was a fuse.Still no climate/heat/AC/blower at all.Any fuses else where?What else should I check?Also headlights motor does stop and clicks unless **** is pushed back in some.
