95 exhaust?
Old Apr 3, 2017 | 05:25 AM
Shanes1031's Avatar
Shanes1031
Default 95 exhaust?
which is better magnaflow catback or the obx
Old Apr 3, 2017 | 07:11 AM
THE 383 admiral's Avatar
THE 383 admiral
The OBX system needs adjusting and modifications. If you do not have the tools or resources to perfect the fit.
This makes magnaflo the direct bolt-on winner.
Sound and performance the OBX system has a great low tone without drone.
Old Apr 3, 2017 | 09:39 AM
Shanes1031's Avatar
Shanes1031
I will be having a shop install it, what type of modifications are needed
Old Apr 3, 2017 | 06:59 PM
keithhogan's Avatar
keithhogan
put a Magnaflow on my 95 in January, easy to install and no mods required. Sounds and looks great, but contrary to other reports I experience drone at low RPMs. Still am very pleased.
Old Apr 3, 2017 | 08:16 PM
THE 383 admiral
Mostly QC. It would appear OBX just copied a system and made a jig? I believe other Mfg's install test fit. Then make a jig. end results true bolt on. Some elbows did not have true flush ends. Simply true the ends with a angle grinder, chamfer the edges with a file. Learned from my 1st cars install.
The OBX clamps suck! Toss them. Dixon makes HD T-clamps .60 thick.
After tweaking The complete system. Fit very nice. I was impressed with the sound.
Non OE,
I did not like the multi piece S-adapter fitment, also more possble leaks!
2nd car. I decided to modify the 2 -1/2 OBX header collector. Now 3" with a resonator straight section combo. I simply made my own S-pipe using left over stainless from my F-bodies supertrapp kit. The extra work is well worth the final end results. Excellent looking. And sounds great!
I must warn a shop will add more time. Plus material. making your install price higher.
Old Apr 3, 2017 | 10:18 PM
Shanes1031's Avatar
Shanes1031
I may go with the magnaflow, not sure what you mean by drone
Old Apr 3, 2017 | 10:31 PM
THE 383 admiral
A low, reverberating sound wave, harmonic frequency. around 1,500 - 2000 RPM's. Many systems including high end. Produce this noise. Some cars outrageously deafening.
Old Apr 3, 2017 | 10:34 PM
Shanes1031's Avatar
Shanes1031
Seems a lot run the magnaflow setup so they must not be that bad. I also looked at corsa and borla systems but kind of pricey lol
Old Apr 4, 2017 | 10:54 AM
MrJoelieC's Avatar
MrJoelieC
I have Magna flow.... It does drone a bit in 6th gear on the highway....
To 95 exhaust?
