GM Screw size: 4.5M x 75 thread angle??????????
Old Sep 26, 2002 | 10:42 AM
Derf's Avatar
Derf
Default GM Screw size: 4.5M x 75 thread angle??????????
Replacing the TPS on the Throttle body. Messed up a screw. Could not find the same size except at the GM dealer. Had to buy 14 screws to get one, 16 bucks. Screw size 4.5mx75thread. Then needed a tap to clean the threads, special order although available, 4 bucks. GM probably did this to screw with me. I could just drill it out and go with a 10mx32 but that would not be original. Just venting. :mad
Old Sep 26, 2002 | 10:58 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: GM Screw size: 4.5M x 75 thread angle?????????? (Derf)
:lol: Somebody else has this problem? I went to Diamond Screw here in BG. If it exists they either have it or can get it. They came to the conclusion that it doesn't exist.
Old Sep 26, 2002 | 11:46 AM
Rick93Z07's Avatar
Rick93Z07
Default Re: GM Screw size: 4.5M x 75 thread angle?????????? (Nathan Plemons)
4.5mx75 is a common thread. Ford uses it all over their vehicles. The little hardware store up my street had plenty of nuts, bolts, taps and dies in this size.
Old Sep 27, 2002 | 08:18 PM
Derf's Avatar
Derf
Default Re: GM Screw size: 4.5M x 75 thread angle?????????? (Rick93Z07)
If you don't mind. When your near that hardware store could you get me four 1.25" 4.5M x 75 thread angle with a torx head please. Be glad to pay for them and what mail costs. I think you can fold them in a piece of cardboard and put in an envelope. They are really not available around here. Once you get them I will email you my address, and if you don't mind I will pay you with paypal or send you a check. Thanks.
:yesnod:
Old Sep 28, 2002 | 12:59 AM
jfb's Avatar
jfb
For the record thats 4.5mm x .75, not 75. The second number in metric screws is the pitch (thread to thread).
To GM Screw size: 4.5M x 75 thread angle??????????
